Article ID : 00177806 / Last Modified : 17/09/2020
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2015-2020 models)
    Select your model year and refer to the relevant compatibility chart.
    You can check your model year with the model series name or model name:
    2020 models (see the compatibility chart)
    • A89 Series: (KD-65A89 / KD-55A89)
    • A87 Series: (KD-65A87 / KD-55A87)
    • A85 Series: (KD-65A85 / KD-55A85)
    • A8 Series: (KD-65A8 / KD-55A8)
    • XH9505 Series: (KD-85XH9505 / KD-75XH9505 / KD-65XH9505 / KD-55XH9505 / KD-49XH9505)
    • XH9196 Series: (KD-49XH9196 / KD-43XH9196)
    • XH8599 Series: (KD-49XH8599 / KD-43XH8599)
    • XH8596 Series: (KD-49XH8596 / KD-43XH8596)
    • XH8588 Series: (KD-49XH8588 / KD-43XH8588)
    • XH8577 Series: (KD-49XH8577)
    • XH8505 Series: (KD-49XH8505 / KD-43XH8505)
    • XH8196 Series: (KD-65XH8196 / KD-55XH8196 / KD-49XH8196 / KD-43XH8196)
    • XH8096 Series: (KD-85XH8096 / KD-75XH8096 / KD-65XH8096 / KD-55XH8096 / KD-49XH8096 / KD-43XH8096)
    • XH8077 Series: (KD-65XH8077 / KD-55XH8077 / KD-49XH8077 / KD-43XH8077)
    • XH8005 Series: (KD-55XH8005 / KD-49XH8005 / KD-43XH8005)
    • X7056 Series: (KD-65X7056 / KD-55X7056 / KD-49X7056 / KD-43X7056)
    • X7055 Series: (KD-65X7055 / KD-55X7055 / KD-49X7055 / KD-43X7055)
    • X7053 Series: (KD-65X7053 / KD-55X7053 / KD-49X7053 / KD-43X7053)
    • X7052 Series: (KD-65X7052 / KD-55X7052 / KD-49X7052 / KD-43X7052)
    2019 models (see the compatibility chart)
    • A8G Series: (KD-55AG8 / KD-65AG8)
    • A9G Series: (KD-55AG9 / KD-65AG9 / KD-77AG9)
    • WG663 Series: (KDL-43WG663 / KDL-50WG663)
    • WG665 Series: (KDL-43WG665 / KDL-50WG665)
    • XG7002 Series: (KD-43XG7002 / KD-49XG7002 / KD-55XG7002 / KD-65XG7002)
    • XG7003 Series: (KD-43XG7003 / KD-49XG7003 / KD-55XG7003 / KD-65XG7003)
    • XG7004 Series: (KD-43XG7004 / KD-49XG7004 / KD-55XG7004 / KD-65XG7004)
    • XG7005 Series: (KD-43XG7005 / KD-49XG7005 / KD-55XG7005 / KD-65XG7005)
    • XG7073 Series: (KD-43XG7073 / KD-49XG7073 / KD-55XG7073 / KD-65XG7073)
    • XG7077 Series: (KD-43XG7077 / KD-49XG7077 / KD-55XG7077 / KD-65XG7077)
    • XG7093 Series: (KD-43XG7093 / KD-49XG7093 / KD-55XG7093 / KD-65XG7093)
    • XG7096 Series: (KD-43XG7096 / KD-49XG7096 / KD-55XG7096 / KD-65XG7096)
    • XG8096 Series: (KD-43XG8096 / KD-49XG8096 / KD-55XG8096 / KD-65XG8096 / KD-75XG8096)
    • XG8196 Series: (KD-43XG8196 / KD-49XG8196 / KD-55XG8196 / KD-65XG8196)
    • XG8305 Series: (KD-43XG8305 / KD-49XG8305)
    • XG8377 Series: (KD-49XG8377)
    • XG8388 Series: (KD-43XG8388 / KD-49XG8388)
    • XG8396 Series: (KD-43XG8396 / KD-49XG8396)
    • XG8399 Series: (KD-43XG8399 / KD-49XG8399)
    • XG8505 Series: (KD-55XG8505 / KD-65XG8505 / KD-75XG8505)
    • XG8577 Series: (KD-55XG8577 / KD-65XG8577)
    • XG8588 Series: (KD-55XG8588 / KD-65XG8588 / KD-75XG8588)
    • XG8596 Series: (KD-55XG8596 / KD-65XG8596 / KD-75XG8596 / KD-85XG8596)
    • XG8599 Series: (KD-55XG8599 / KD-65XG8599 / KD-75XG8599)
    • XG8796 Series: (KD-55XG8796 / KD-65XG8796 / KD-75XG8796)
    • XG9005 Series: (KD-49XG9005)
    • XG9505 Series: (KD-55XG9505 / KD-65XG9505 / KD-75XG9505 / KD-85XG9505)
    • ZG9 Series: (KD-85ZG9 / KD-98ZG9)
    2018 models (see the compatibility chart)
    • AF8 Series: (KD-55AF8 / KD-65AF8)
    • AF9 Series: (KD-55AF9 / KD-65AF9)
    • WF663 Series: (KDL-43WF663)
    • WF804 Series: (KDL-43WF804 / KDL-49WF804)
    • WF805 Series: (KDL-43WF805 / KDL-49WF805)
    • XF7596 Series: (KD-43XF7596 / KD-49XF7596 / KD-55XF7596 / KD-65XF7596)
    • XF8096 Series: (KD-43XF8096 / KD-49XF8096 / KD-55XF8096)
    • XF8305 Series: (KD-60XF8305 / KD-70XF8305)
    • XF8505 Series: (KD-43XF8505 / KD-49XF8505 / KD-55XF8505 / KD-65XF8505)
    • XF8577 Series: (KD-43XF8577 / KD-49XF8577 / KD-55XF8577 / KD-65XF8577)
    • XF8588 Series: (KD-43XF8588 / KD-49XF8588 / KD-55XF8588 / KD-65XF8588)
    • XF8596 Series: (KD-43XF8596 / KD-49XF8596 / KD-55XF8596 / KD-65XF8596 / KD-75XF8596 / KD-85XF8596)
    • XF8599 Series: (KD-43XF8599 / KD-49XF8599 / KD-55XF8599 / KD-65XF8599)
    • XF8796 Series: (KD-43XF8796 / KD-49XF8796 / KD-55XF8796 / KD-65XF8796)
    • XF9005 Series: (KD-49XF9005 / KD-55XF9005 / KD-65XF9005 / KD-75XF9005)
    • ZF9 Series: (KD-65ZF9 / KD-75ZF9)
    2017 models (see the compatibility chart)
    • A1 Series:  (KD-55A1 / KD-65A1)
    • RE4 Series: (KDL-32RE400 / KDL-32RE403 / KDL-32RE405 / KDL-40RE450     / KDL-40RE453 / KDL-40RE455)
    • WE61 and WE66 Series: (KDL-32WE610 / KDL-32WE613 / KDL-32WE615 / KDL-40WE660 / KDL-40WE663 / KDL-40WE665 / KDL-49WE660 / KDL-49WE663 / KDL-49WE665)
    • WE75 Series: (KDL-43WE750 / KDL-43WE753 / KDL-43WE755 / KDL-49WE750 / KDL-49WE753 / KDL-49WE755)
    • XE70 Series: (KD-43XE7000 / KD-43XE7002 / KD-43XE7003 / KD-43XE7005 / KD-49XE7000 / KD-49XE7002 / KD-49XE7003 / KD-49XE7005 / KD-55XE7000 / KD-55XE7002 / KD-55XE7003 / KD-55XE7005 / KD-65XE7002 / KD-65XE7003 / KD-65XE7005)
    • XE80 Series: (KD-43XE8005 / KD-49XE8005)
    • XE85 Series: (KD-55XE8505 / KD-65XE8505)
    • XE90 Series: (KD-49XE9005 / KD-55XE9005 / KD-65XE9005 / KD-75XE9005)
    • XE93 and XE94 Series: (KD-55XE9305 / KD-65XE9305 / KD-75XE9405)
    2016 models (see the compatibility chart)
    • SD85 and SD80 Series: (KD-50SD8005 / KD-55SD8505 / KD-65SD8505)
    • XD70 Series: (KD-49XD7004 / KD-49XD7005 / KD-55XD7004 / KD-55XD7005)
    • XD75 Series: (KD-65XD7504 / KD-65XD7505)
    • XD80 Series: (KD-43XD8005 / KD-43XD8077 / KD-43XD8088 / KD-43XD8099 / KD-49XD8005 / KD-49XD8077 / KD-49XD8088 / KD-49XD8099 / KD-55XD8005)
    • XD83 Series: (KD-43XD8305 / KD-49XD8305)
    • XD85 Series: (KD-55XD8505 / KD-55XD8577 / KD-55XD8588 / KD-55XD8599 / KD-65XD8505 / KD-65XD8577 / KD-65XD8599 / KD-75XD8505 / KD-85XD8505)
    • XD93 and XD94 Series: (KD-55XD9305 / KD-65XD9305 / KD-75XD9405)
    • ZD9 Series: (KD-65ZD9 / KD-75ZD9 / KD-100ZD9)
    2015 models (see the compatibility chart)
    • S80C Series: (KD-55S8005C / KD-65S8005C)
    • S85C Series: (KD-55S8505C / KD-65S8505C)
    • X80C Series: (KD-49X8005C / KD-55X8005C)
    • X83C Series: (KD-43X8301C / KD-43X8305C / KD-43X8307C / KD-43X8308C / KD-43X8309C / KD-49X8301C / KD-49X8305C / KD-49X8307C / KD-49X8308C / KD-49X8309C)
    • X85C Series: (KD-55X8501C / KD-55X8505C / KD-55X8507C / KD-55X8508C / KD-55X8509C / KD-65X8501C / KD-65X8505C / KD-65X8507C / KD-65X8508C / KD-65X8509C / KD-75X8501C / KD-75X8505C)
    • X90C and X91C Series: (KD-55X9005C / KD-65X9005C / KD-75X9105C)
    • X93C and X94C Series: (KD-55X9305C / KD-65X9305C / KD-75X9405C)
