Article ID : 00251074 / Last Modified : 20/01/2026Print
    Function/Option List
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article.
    FunctionOption
    Accessibility shortcutAvailable functions: TalkBack, Text magnification, Screen reader
    Screen ReaderSpeech rate: 9 levels
    Voice SearchTargeted search areas: Apps, TV programs, video content
    Audio Description/Video DescriptionSwitch Audio Description
    Tactile dots on a remote controlPLAY, AUDIO, numerical 5, and Channel Up
    Text MagnificationColor: 3 combinations
    Duration: 4 choices
    On timerDay: Every day, Every Mon-Fri, Day, Weekly
    Time
    Duration: 1h to 23h
    Input: broadcast and external inputs
    Channel (When Channel is selected in Input)
    TV on volume
    Closed Captions Cable/Antenna DigitalCharacter size: Small, Standard, Large
    Character style: 8 choices
    Character color: 9 choices
    Character opacity: Solid, Flashing, Translucent
    Edge type: 6 choices
    Edge color: 8 choices
    Background color: 9 choices
    Background opacity: Solid, Flashing, Translucent
    Window color: 9 choices
    Window opacity: Solid, Translucent
    Closed Captions Streaming & other contentText size: 5 choices
    Font: 9 choices
    Text color: 8 choices
    Text opacity: 4 choices
    Edge type: 5 choices
    Background color: 8 choices
    Background opacity: 4 choices
    Window color: 8 choices
    Window opacity: 4 choices
    TV remote control designed for tabletop useRequirement: used on a flat surface
