Article ID : 00161671 / Last Modified : 29/03/2019Print
    How to connect a Mobile High Definition Link (MHL) device to the TV using a MHL-to-HDMI adaptor
    The image below provides an example of the connections described in this solution: Image
    1. Connect the MHL™ device to an MHL-to-HDMI adaptor, and connect the adapter to a USB power supply.
    2. Connect the adapter to a TV using a HDMI® cable. The MHL icon appears on the status bar of the MHL device after a connection is established.
    3. Set the TV to the HDMI input. The TV launcher application starts automatically. Follow the instructions on the screen of the MHL-device to view media files on the TV.
