The recommended viewing distance depends on your TV’s screen size and resolution.
Quick guide:
- 4K TVs: At least 1.5 times the screen’s vertical height
- High Definition (HD) TVs: At least 3 times the screen’s vertical height
- Standard Definition (SD) TVs: Approximately 6 times the screen’s vertical height
Notes:
These are minimum recommended distances. Adjust your seating position based on the content, room layout, viewing environment, and your personal comfort. Take regular breaks during extended viewing.
To find your TV’s vertical screen height, check its specifications under Dimensions and Weight.
Recommended viewing distance for 4K TVs
For a 4K TV, sit at least 1.5 times the screen’s vertical height away. At this distance, individual pixels should no longer be visible to the naked eye.
| TV size | Approximate minimum viewing distance |
| 43 inches | 90 cm / 2.95 ft |
| 49 inches | 1 m / 3.28 ft |
| 55 inches | 1 m / 3.28 ft |
| 65 inches | 1.2 m / 3.94 ft |
| 75 inches | 1.4 m / 4.60 ft |
| 85 inches | 1.6 m / 5.25 ft |
Recommended viewing distance for HD TVs
For a High Definition TV, sit at least 3 times the screen’s vertical height away.
| 22 inches | 80 cm / 2.62 ft |
| 26 inches | 1 m / 3.28 ft |
| 32 inches | 1.2 m / 3.94 ft |
| 40 inches | 1.5 m / 4.92 ft |
| 43 inches | 1.7 m / 5.57 ft |
| 46 inches | 1.7 m / 5.57 ft |
| 49 inches | 1.9 m / 6.23 ft |
| 50 inches | 1.9 m / 6.23 ft |
| 55 inches | 2.1 m / 6.89 ft |
| 60 inches | 2.3 m / 7.55 ft |
Recommended viewing distance for SD TVs
For a Standard Definition TV, sit approximately 6 times the screen’s vertical height away.
