What the app?! How to download, install and troubleshoot Google TV™ and Android TV™ apps
Your Google TV or Android TV offers more than just watching regular TV. Like on your smartphone, you can install third-party apps from your favourite service providers, organisations or game studios. This article will briefly explain how you can download, manage, and troubleshoot applications. All navigation explained in this article is done with the arrows on your remote control. Each action (OK, enter) is done by pressing the central button of your arrow keys.
IMPORTANT:
- This article applies to Google TV / Android TV models only.
- If your TV is not a Google or Android TV, it has pre-installed apps but cannot download additional apps. For more information and alternative ways to get new apps, refer to this article: BRAVIA TV apps: How to install, update, and troubleshoot.
Notes:
- If you don't know your TV type, refer to this article: How to check if your BRAVIA TV is a Google TV, Android TV™, or other TV.
- If you're looking for information about a specific app, check the app service provider's support website. Third-party apps are updated according to the app developer’s schedule or discretion.
The following topics provide information about Google/Android TV apps. Press or tap on the question below to quickly jump to the relevant section:
- How do I download apps on my Google TV or Android TV?
- Why can't I find apps, or why are they unavailable to me?
- Why can't I download, install, or update apps on my Google TV or Android TV?
- Managing apps on your Google TV or Android TV
- How do I update a Google TV or Android TV app?
- How do I uninstall an app on Google TV or Android TV?
- What do I do if a Google / Android TV app is not working?
You can download apps by accessing the Google Play Store on your Google TV and Android TV. The Google Play Store is where you can find all available apps for both Google TV and Android TV.
If you can't find an app in the Google Play Store, it's possible it doesn't exist or is currently unavailable on Google TV and Android TV platforms. A smartphone app may not always have an equivalent version on Google TV or Android TV. In that case, you may want to consider casting content to your TV instead.
How to download TV apps on Google TV
- There are several tabs at the top of your Home screen: Search, Home, Apps, and Library. Use your remote control arrow keys to navigate to the Apps tab.
- The Apps tab screen displays your apps listed in a row. There is a search bar below this row that allows you to search for apps and games. You can also browse various app categories.
- Alternatively, press the input key on your remote (
). You can add apps to your input menu by moving to the right and selecting them from the available list. The Google Play Store is one of those apps. That way, the Google Play Store becomes quickly accessible via the input menu.
- Finally, you can use the voice search or keyboard search on the Home screen to look for apps without using the Apps tab. If the app is available, you will get a Google Play Store search result, and you'll be able to download the app immediately.
How to download TV apps on Android TV
- There are several tabs at the top of your Home screen: Search, Home, Discover, and Apps. Use your remote control arrow keys to navigate to the Apps tab.
- When you navigate down in the Apps tab, you'll first see a button to open the Google Play Store before continuing down in the app tile list. On the remote control, press OK to access the Google Play Store.
- The Google Play Store features examples of popular apps, but you can also use the Search function located at the top of the screen. On the remote control, press OK to use the voice search or move to the right to activate the keyboard search.
Alternatively, you can use the voice search or keyboard search on the Home screen to look for apps without using the Apps tab. If the app is available, you will get a Google Play Store search result, and you'll be able to download the app immediately.
Why can't I find apps, or why are they unavailable to me? How do I know my Google TV or Android TV supports an app?
There are two main reasons you can't find or use an app: availability and location. In this case, location can mean your country/region and sometimes even territories.
First, a service provider doesn't always have an app on the market. It's possible that your favourite smartphone app doesn't have an equivalent (yet) on Google TV or Android TV. Google has an online list of available Android TV apps.
Secondly, your location (country/region, territory) also matters. Some apps are only available in a certain country/region. However, these apps might one day become available in more countries/regions if the app provider decides to expand their support. Yes, it's a complicated patchwork out there. When in doubt, it's always best to contact the service provider and check their website for supported countries/regions and information.
Refer to this article for troubleshooting tips: BRAVIA TV apps: How to install, update, and troubleshoot.
Now that you're ready to install all your favourite apps on your TV, it's time to make it easy for you to navigate and manage all these apps. Let's have a look at the app mini-menu.
The app mini-menu
Every app has a mini-menu that allows you to take several actions. Hover over the app (as if to open it), and on your remote control, long-press the OK button. If you accidentally opened the app, you didn't press the OK button long enough because a pop-up menu should appear:
Google TV mini-menu
- Move
- Open
- View details
Android TV mini-menu
- Open
- Move
- Add to favourites
- Info
- Uninstall
Adding TV apps to the favourites quick menu
Google TV
The Your Apps bar on the Home screen includes all your installed apps, so there's no need to add any new ones here. To move your favourite apps to a more convenient position, refer to the next chapter: "Moving TV apps around in the favourites menu and app screen."
Android TV
- On your Home screen, there's a banner featuring your favourite apps. It's a quick selection bar.
- Navigate to the right to reach a plus sign. Press OK to add new apps to your quick selection bar.
You can also use the app mini-menu to bookmark an app to favourites.
This applies to both Google TV and Android TV
- Hover over the app (as if to open it), and on your remote control, long-press the OK button to open the app mini-menu.
- Select Move and drag the app tile to your preferred position.
- On your remote control, press Back to stop moving the app around.
It's not entirely necessary for you to manually update an app. If your Google TV or Android TV is connected to the internet, it will automatically update your apps whenever the service provider releases a new version. Your apps should run the latest version if your TV is connected to the internet.
Google updates applications in phases, so it's possible that your TV hasn't received an app update yet, even though it's available. In that case, there is a way to check for updates manually:
- Google TV: access the Google Play Store via voice search or the input menu.
- Android TV: navigate to the Apps tab and access the Google Play Store.
Once in the Google Play Store, you can check the Apps and games management, which is hidden under your Google Account icon in the top right corner. Under the Google Account icon, you'll find Apps and games management, in which you can check any available app updates.
If you're not using an app anymore, you might as well remove it and clear some memory:
- Use your remote control arrow keys to navigate to the Apps tab.
- Navigate down to see all your apps listed in a grid.
- You can hover over any app you want to delete and access the mini-menu (long-press OK button) to select View details (Google TV) or Uninstall (Android TV) to uninstall.
- If the uninstall option is greyed out, you can't uninstall the app (e.g. YouTube™). Pre-installed TV apps can't be removed.
What do I do if a Google TV or Android TV app is not working?
An app might have an issue like a lost internet connection, a frozen menu or some sound and image glitches. If you feel like something's wrong with an app, the simplest thing to do is reset the app by doing a force stop.
