Article ID : 00248363 / Last Modified : 20/01/2026Print
Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2020 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING: There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For Safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    Sony original Wall-Mount Bracket
    Compatibility chart
    About the Strength of Walls
    About Screws
    • The screw hole distance measurements: Width x Height expressed in mm
      The diagram shows the rear side of the BRAVIA TV.
      back side of the BRAVIA TV
      1. W (width)
      2. H (height)
      3. screw holes
      NOTE:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals of your TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC Power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility chart.
      Ac Power adapter size
      1. W (width)
      2. H (height)
      3. D (depth)
    Product NameModel NameReference
    Wall-Mount BracketSU-WL450-
    Wall-Mount BracketSU-WL850-
    Wall-Mount BracketSU-WL900
    • Load capacity: 60kg
    • VESA® hole pitch/Screw hole size (W x H) mm: 300 x 300 / 400 x 400
    Compatibility chart
    2020 models
    ★Series NameModel NameInchesSU-WL450SU-WL850
    • Weight of TV: within 60kg
    • VESA hole pitch/Screw hole size
      (W x H) mm:
    (W x H) mm
    Length of power cord (mains lead)Weight of TV without Stand
    A9 SeriesKD-48A948✓ *1300 x 3001.5 m13.9 kg
    A89 SeriesKD-65A8965✓ *1300 x 3002 m21.8 kg
    A89 SeriesKD-55A8955✓ *1300 x 3001.5 m16.8 kg
    A87 SeriesKD-65A8765✓ *1300 x 3002 m21.8 kg
    A87 SeriesKD-55A8755✓ *1300 x 3001.5 m16.8 kg
    A85 SeriesKD-65A8565✓ *1300 x 3002 m21.8 kg
    A85 SeriesKD-55A8555✓ *1300 x 3001.5 m16.8 kg
    A8 SeriesKD-65A865✓ *1300 x 3002 m21.8 kg
    A8 SeriesKD-55A855✓ *1300 x 3001.5 m16.8 kg
    ZH8 SeriesKD-85ZH885✓ *1--400 x 4002 m65.6 kg
    ZH8 SeriesKD-75ZH875✓ *1-400 x 4002 m47.9 kg
    XH9505 SeriesKD-85XH950585✓ *1-400 x 4002 m46.0 kg
    XH9505 SeriesKD-75XH950575✓ *1400 x 3001.5 m33.1 kg
    XH9505 SeriesKD-65XH950565✓ *1300 x 3001.5 m22.3 kg
    XH9505 SeriesKD-55XH950555✓ *1300 x 3001.5 m16.8 kg
    XH9505 SeriesKD-49XH950549✓ *1--200 x 2001.5 m13.3 kg
    XH9299 SeriesKD-75XH929975✓ *1300 x 3001.5 m32.9 kg
    XH9299 SeriesKD-65XH929965✓ *1300 x 3001.5 m22.2 kg
    XH9299 SeriesKD-55XH929955✓ *1300 x 3001.5 m16.5 kg
    XH9296 SeriesKD-75XH929675✓ *1300 x 3001.5 m32.9 kg
    XH9296 SeriesKD-65XH929665✓ *1-300 x 3001.5 m22.2 kg
    XH9296 SeriesKD-55XH929655✓ *1300 x 3001.5 m16.5 kg
    XH9288 SeriesKD-75XH928875✓ *1300 x 3001.5 m32.9 kg
    XH9288 SeriesKD-65XH928865✓ *1300 x 3001.5 m22.2 kg
    XH9288 SeriesKD-55XH928855✓ *1300 x 3001.5 m16.5 kg
    XH9196 SeriesKD-49XH919649✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    Length of AC Power Cord
    0.5 m
    AC Power adapter size (W x H x D)
    (191 x 80 x 39) or (170 x 85 x 40)
    13.2 kg
    XH9196 SeriesKD-43XH919643✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH9096 SeriesKD-85XH909685✓ *1-400 x 4001.5 m45.8 kg
    XH9096 SeriesKD-75XH909675✓ *1300 x 3001.5 m32.9 kg
    XH9096 SeriesKD-65XH909665✓ *1300 x 3001.5 m22.2 kg
    XH9096 SeriesKD-55XH909655✓ *1300 x 3001.5 m16.5 kg
    XH9077 SeriesKD-65XH907765✓ *1300 x 3001.5 m22.2 kg
    XH9077 SeriesKD-55XH907755✓ *1300 x 3001.5 m16.5 kg
    XH9005 SeriesKD-75XH900575✓ *1300 x 3001.5 m32.9 kg
    XH9005 SeriesKD-65XH900565✓ *1300 x 3001.5 m22.2 kg
    XH9005 SeriesKD-55XH900555✓ *1300 x 3001.5 m16.5 kg
    XH8599 SeriesKD-49XH859949✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    XH8599 SeriesKD-43XH859943✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8596 SeriesKD-49XH859649✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m (Russia: 1.5 m)
    13.2 kg
    XH8596 SeriesKD-43XH859643✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8588 SeriesKD-49XH858849✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    XH8588 SeriesKD-43XH858843✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8577 SeriesKD-49XH857749✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    XH8505 SeriesKD-49XH850549✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    13.2 kg
    XH8505 SeriesKD-43XH850543✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    10.8 kg
    XH8196 SeriesKD-65XH819665✓ *1300 x 3001.5 m21.7 kg
    XH8196 SeriesKD-55XH819655✓ *1300 x 3001.5 m16.0 kg
    XH8196 SeriesKD-49XH819649✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (158 x 70.5 x 35) or (155 x 67 x 36.5)
    11.6 kg
    XH8196 SeriesKD-43XH819643✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.4 kg
    XH8096 SeriesKD-85XH809685✓ *1-400 x 4001.5 m44.1 kg
    XH8096 SeriesKD-75XH809675✓ *1300 x 3001.5 m31.8 kg
    XH8096 SeriesKD-65XH809665✓ *1300 x 3001.5 m21.7 kg
    XH8096 SeriesKD-55XH809655✓ *1300 x 3001.5 m16.0 kg
    KD-49XH809649✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    11.6 kg
    XH8096 SeriesKD-43XH809643✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    9.4 kg
    XH8077 SeriesKD-65XH807765✓ *1300 x 3001.5 m21.7 kg
    XH8077 SeriesKD-55XH807755✓ *1300 x 3001.5 m16.0 kg
    XH8077 SeriesKD-49XH807749✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.6 kg
    XH8077 SeriesKD-43XH807743✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.4 kg
    XH8005 SeriesKD-55XH800555✓ *1300 x 3001.5 m16.0 kg
    XH8005 SeriesKD-49XH800549✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    1.5 m
    11.6 kg
    XH8005 SeriesKD-43XH800543✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    1.5 m
    9.4 kg
    X7056 SeriesKD-65X705665✓ *1-300 x 3001.5 m20.5 kg
    X7056 SeriesKD-55X705655✓ *1--200 x 2001.5 m15.4 kg
    X7056 SeriesKD-49X705649✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (155 x 67 x 36.5) or (158 x 70.5 x 35)
    11.9 kg
    X7056 SeriesKD-43X705643✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    (151 x 65 x 32) or (157 x 65 x 32)
    9.7 kg
    X7055 SeriesKD-65X705565✓ *1-300 x 3001.5 m20.5 kg
    X7055 SeriesKD-55X705555✓ *1--200 x 2001.5 m15.4 kg
    X7055 SeriesKD-49X705549✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    X7055 SeriesKD-43X705543✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.7 kg
    X7053 SeriesKD-65X705365✓ *1-300 x 3001.5 m20.5 kg
    X7053 SeriesKD-55X705355✓ *1--200 x 2001.5 m15.4 kg
    X7053 SeriesKD-49X705349✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    X7053 SeriesKD-43X705343✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.7 kg
    X7052 SeriesKD-65X705265✓ *1-300 x 3001.5 m20.5 kg
    X7052 SeriesKD-55X705255✓ *1--200 x 2001.5 m15.4 kg
    X7052 SeriesKD-49X705249✓ *1--200 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    11.9 kg
    X7052 SeriesKD-43X705243✓ *1--100 x 200DC Cable length of AC adapter
    1.5 m
    0.5 m
    9.7 kg
    *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    If the strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult Sony dealers or licensed contractors.
    About Screws
    When attaching the Wall-Mount Bracket to the TV, use the screws supplied with the Wall-Mount Bracket.
    The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
    For details about the screws, refer to the Installation instructions (Wall-Mount Bracket) for the TV or Operating Instructions or Reference Guide for the TV.
