Article ID : 00342222 / Last Modified : 20/01/2026Print
    Compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TVs (2024 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING! There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For Safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    • The screw hole distance measurements: Width x Height expressed in mm
      Note: This diagram shows the rear side of a BRAVIA TV.
      Back side of the BRAVIA TV. There is a "C: Screw holes" on the back of the TV, and in this image the horizontal distance between the left and right holes is shown as "A: W (width)" and the vertical distance between the upper and lower holes is shown as "B: H (heigjt)".
      • A: W (width)
      • B: H (height)
      • C: Screw holes
      Notes:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals that come with the TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC Power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility chart.
      Ac Power adapter size. The longest part of the adapter is "A: W (width)". When placed with the "A" side facing toward you, the distance from the top to the bottom of the left and right sides of the adapter is "B: H (height)" and the depth is "C: D (depth)".
      • A: W (width)
      • B: H (height)
      • C: D (depth)
    Sony original Wall-Mount Bracket
    Product NameModel NameReference
    Wall-Mount BracketSU-WL450-
    Wall-Mount BracketSU-WL850-
    Wall-Mount BracketSU-WL900
    • Load capacity: 60kg
    • VESA®hole pitch/Screw hole size (W x H) mm: 300 x 300 / 400 x 400
    Compatibility chart
    2024 models
    Series NameModel NameInchesSU-WL450SU-WL850
    • Weight of TV: Within 60kg
    • VESA hole pitch/Screw hole size (W x H) mm:
    (W x H) mm
    Length of power cord (mains lead)
    Weight of TV without Stand
    (Approx.)
    BRAVIA 9K-85XR9085*1-400 x 4003.5 m52.4 kg
    BRAVIA 9K-75XR9075*1-300 x 3003.5 m42.3 kg
    BRAVIA 8K-77XR8077*1*2300 x 3003.5 m32.3 kg
    BRAVIA 8K-77XR8377*1*2300 x 3003.5 m32.3 kg
    BRAVIA 8K-77XR8477*1*2300 x 3003.5 m32.3 kg
    BRAVIA 8K-65XR8065*1*2300 x 3001.5 m22.3 kg
    BRAVIA 8K-55XR8055*1*2300 x 3001.5 m17.1 kg
    BRAVIA 8K-55XR8355*1*2300 x 3001.5 m17.1 kg
    BRAVIA 8K-55XR8455*1*2300 x 3001.5 m17.1 kg
    BRAVIA 8K-65XR8365*1*2300 x 3001.5 m22.3 kg
    BRAVIA 8K-65XR8465*1*2300 x 3001.5 m22.3 kg
    BRAVIA 7K-85XR7085*1-400 x 4001.5 m48.6 kg
    BRAVIA 7K-75XR7075*1-300 x 3001.5 m38.3 kg
    BRAVIA 7K-65XR7065*1*2300 x 3001.5 m27.1 kg
    BRAVIA 7K-55XR7055*1*2300 x 3001.5 m19.9 kg
    • *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    • *2 Use of the terminals may be limited depending on usage of the TV.
    About the Strength of Walls
    • The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    • If the wall strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult a Sony dealer or a licensed contractor.
    About Screws
    • When attaching the Wall-Mount Bracket to the TV, use screws supplied with the Wall-Mount Bracket. The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    • If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
    • For details about the screws, refer to the Installation instructions (Wall-Mount Bracket) for the TV or Operating Instructions or Reference Guide for the TV.
