I changed the subtitle setting, but the setting is not being retained
If you want the subtitle setting to be retained indefinitely, follow these steps.
- Open the
Settings screen. How to access Settings
- The next steps will depend on your TV menu options:
- Select Channels & Inputs → Preferences (Channels) → Subtitle setting → Broadcast → Subtitle.
- Select Channels & Inputs → Preferences (Channels) → Subtitle setting → Subtitle.
- Select Watching TV → Preferences (Channels) → Subtitle setting → Broadcast → Subtitle.
- Select Watching TV → Channels → Channel setup → Digital Set-up → Subtitle Set-up → Subtitle settings.
- Select Channel setup → Digital Set-up → Subtitle Set-up → Subtitle settings.
- Select Watching TV → Channel setup → Digital Setup → Subtitle Setup → Subtitle.
- Select BRAVIA Settings → Channel setup → Digital Setup → Subtitle Setup → Subtitle settings.
- Select one of the following.
- Select Off if you want the subtitles to remain OFF.
- Select Basic if you always want subtitles to be displayed.
- Select For Hard Of Hearing if you always want the subtitles for hard of hearing.
