Article ID : 00350142 / Last Modified : 27/05/2026Print
    When using the Acoustic Center Sync feature, noise is heard from the TV
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
    When using the TV's Acoustic Center Sync function, you may hear a hissing sound. If this happens, in the area where the power cable comes out of the back of the TV and the area around other external devices, make sure to keep the cables of the Acoustic Center Sync device away from those cables.
    Note: Due to the nature of electronic devices, you may hear a slight noise when you're very close to the TV speakers. This is not a malfunction. When watching TV from an appropriate viewing distance, this noise should not be audible.
    Additionally, there may be cases where the audio signal of the content being played contains components that sound like noise.
