Article ID : 00409486 / Last Modified : 27/08/2026Print
    How to use the Scheduled power on/off feature on your TV
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    Use the Scheduled power on/off feature to automatically turn your TV on or off at a specified time. You can also configure the TV to turn off automatically after it turns on, which can help reduce unnecessary power usage.
    Set up Scheduled power on/off
    1. Press the Home button on the remote control.
    2. Select Dashboard.
    3. Select All Settings.
    4. Select System.
    5. Select Power & energy.
    6. Select Scheduled power on/off.
    Available settings
    The Scheduled power on/off menu has the following options:
    • Auto power on time / Auto power off time
      1. Select the hour using the Down arrow button (00–23).
      2. Select the minutes (00–59).
      3. Press the OK button to save the setting.
    • Power on time type / Power off time type
      Select whether to repeat this setting or use it once.
    • Power off after turning on
      Select how long the TV remains on before it automatically turns off (1h–23h).
    After you finish configuring the settings, press the Back button on the remote control to activate the timer.
