Article ID : 00202428 / Last Modified : 10/02/2026Print
Using hands-free Voice Search (for TVs with a built-in MIC)
    You can search for content or operate the TV hands-free when the Built-in MIC switch on the TV is set to ON or if the “Ok Google detection setting is enabled. Whether the TV supports Built-in MIC varies depending on your region or language.
    Note: The Google Assistant or voice search with the Built-in MIC requires an active internet connection. For Google TV models, you must be signed into a Google Account.
    How to enable or disable the Built-in MIC
    For Google TV™ models:
    • Set the Built-in MIC switch status on the TV to ON or OFF to enable or disable the microphone.
      Note:  You can find detailed information about the location of the Built-in MIC switch in the Reference Guide.
    • Set the Hands-free Mic to ON or OFF.
      1. On the remote control, press the Quick Settings (spanner or gear) button and select  Settings.
      2. Select Privacy → Google Assistant → Hands-free Mic and set it to ON or OFF.
      Note:  The Hands-free Mic setting was added by an update. If the setting does not appear, make sure the Auto-update apps at any time setting is enabled in your Google Play store profile.
    For Android TV™ models:
    1. On the remote control, press the HOME button.
    2. Select  Settings.
    3. The next steps will depend on your TV menu options:
      • Select Device Preferences → Google Assistant → “Ok Google detection. (Android™ 9)
      • Select Google → “Ok Google detection. (Android 8.0)
    You can also set the Built-in MIC when you press the Microphone button on the remote control or select the Microphone.
    How to use the Built-in MIC
    When you face the TV and say, “Ok Google”, you can use the following features hands-free.
    • Voice search
    • TV operation
    You can also use the Built-in MIC when the TV is in Standby mode.
    Note: Supported language settings are English (United States)English (United Kingdom)Français (France), and 日本語 only. Other languages are not supported.
    When you face the TV and say “Ok Google”, the TV’s LED indicator lights up in yellow. During that time, you can face the TV and speak commands, such as asking about the weather forecast, or you can also turn on the TV. When the Built-in MIC is enabled, the TV’s LED indicator stays lit up in amber. To turn off this indicator, perform the following procedure:
    1. Open the  Settings screen.
    2. The next steps will depend on your TV menu options:
      • Select System →  LED indicator → disable Voice detection status(Android 10)
      • Select Device Preferences → LED indicator → disable Built-in MIC LED(Android 9)
      • Select LED indicator → disable Built-in MIC LED. (Android 8.0)
    Note: If the TV supports Google Assistant, you can ask Google Assistant for hands-free operation. For details, refer to the Supported countries/regions/languages and how to use the Google Assistant article.
