What are the compatible HDR (High Dynamic Range) formats on Sony's Android TV?
Format overview
High Dynamic Range (HDR)
HDR enables the handling of brightness information of a wide dynamic range compared to Standard Dynamic Range (SDR) signals used in normal broadcasts. This reproduces shades in bright areas that tend to have blown out highlights and tones in dark areas that tend to lose. It allows the reproduction of images with depth and three-dimensional effects that make it feel as if you were seeing it with your own eyes.
Hybrid Log-gamma (HLG)
HLG is a "hybrid" format that enables the output of HDR images similar to HDR10 and Dolby Vision™ format. It can also express pictures with well-balanced brightness even in TVs in SDR.
HDR10
An HDR technology standard used with Ultra HD Blu-ray.
Dolby Vision
One of the HDR technology standards developed by Dolby. It brings scenes to life with striking highlights, deeper darks, and vibrant colours. Dolby Vision is an HDR solution that creates an immersive, engaging cinematic experience in your home. Watch the https://www.youtube.com/watch?v=_vCYV6RWMOU 4K HDR TV with Dolby Vision video tutorial for more information.
Compatibility information
| Input or Source | HDR format | TV Model Series | |||||||
X93C / X94C |
XD75 |
ZD9 |
A9F |
XG80 |
A8G |
ZG9 | |||
| Streaming Services/Apps | HDR10 | Yes | Yes*1*4 | Yes*1*4 | Yes*5 | Yes | Yes | Yes | |
| Dolby Vision | - | - | Yes*1*2 | Yes*2 | - | Yes*2 | Yes*2 | ||
| HLG | - | Yes*1*4 | Yes*1*4 | Yes*5 | Yes | Yes | Yes | ||
| HDMI | HDR10 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | |
| Dolby Vision | - | - | Yes*1*3 | Yes*3 | - | Yes*3 | Yes*3 | ||
| HLG | Yes*1 | Yes | Yes | Yes | Yes | Yes | Yes | ||
| USB | HDR10 | Yes | Yes | Yes | Yes | Yes | Yes | Yes | |
| Dolby Vision | - | - | - | Yes | - | - | Yes | ||
- *1 Update your TV with the latest firmware version.
- *2 For Dolby Vision, the video streaming app or service must support Dolby Vision. For more information, please contact the app or service provider.
- *3 HDMI devices with Dolby Vision playback such streaming media players and UHD Blu-ray players may require a software update. For more information about the update, contact the device manufacturer.
- *4 The TV supports YouTube™ HDR (HLG/HDR10) starting December 3, 2018. Make sure to update your YouTube app to version 2.04.05 or higher.
- *5 With the software update, YouTube HDR content is now detected automatically and displayed in HDR format.
- - Not supported
- S80C, X83C, X80C, X81C, and 2K resolution TVs released in 2015 don't support HDR.
