Article ID : 00097951 / Last Modified : 07/05/2025Print
What is the minimum viewing distance for my TV?
Best viewing distance from the LCD TV
    The best viewing distance depends on the size of the television screen, as well as the resolution of the television display.
    Notes:
    • Appropriate distance for comfortable viewing depends on the content, the viewing environment as well as the physical conditions of the viewer. We recommend viewing from a suitable distance while taking breaks at regular intervals.
    • The distances below are the minimum distances for your reference. Please adjust these distances according to your personal preferences and the layout of your living space.
    For 4K models
    Recommended minimum distance for viewing 4K TV is 1.5 times the vertical height of the screen. When viewed from this distance, the individual pixels cannot be differentiated by the naked eye. This means that pixels effectively disappear when viewing 4K images. It creates the impression of watching TV pictures with the same detail and resolution as real life.
    TV SizeViewing Distance Range
    (Approx.)
    43 inch90 cm / 2.95 feet
    49 inch1 meter / 3.28 feet
    55 inch
    1 meter / 3.28 feet
    65 inch1.2 meters / 3.94 feet
    75 inch1.4 meters / 4.60 feet
    85 inch1.6 meters / 5.25 feet
    Minimum viewing distance 4k/8K model - 1.5 times vertical screen size
    Note: To know your TV's vertical height, you can refer to the specifications of your TV, under Dimensions and Weight.
    For High Definition models
    The recommended minimum distance for viewing High Definition TV is 3 times the vertical height of the screen.
    (Approx.)
    22 inch80 cm / 2.62 feet
    26 inch1 meter / 3.28 feet
    32 inch1.2 meters / 3.94 feet
    40 inch1.5 meters / 4.92 feet
    43 inch1.7 meters / 5.57 feet
    46 inch1.7 meters / 5.57 feet
    49 inch1.9 meters / 6.23 feet
    50 inch1.9 meters / 6.23 feet
    55 inch2.1 meters / 6.89 feet
    60 inch2.3 meters / 7.55 feet
    Minimum viewing distance HD model - 3 times vertical screen size
    For Standard Definition models
    Recommended distance for viewing Standard Definition TV is 6 times the vertical height of the screen.
