Article ID : 00375465 / Last Modified : 10/02/2026Print
    The sensors on the TV don't work and remote control operations or brightness adjustments can't be performed.
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
    There is a remote control light receiving sensor and an ambient light sensor near the center bottom of the TV screen. Placing something in front of the TV, such as a sound bar, can block the sensors and prevent them from working properly. Move the obstacle away from the TV until the sensors operate normally.
    Notes:
    • Make sure the blue protective tape is removed from the sensors.
    • If the environmental light sensor is set to ON, try turning it to OFF.
