Article ID : 00345252 / Last Modified : 09/11/2026Print
    How to enable the Color Inversion feature on your Google TV™
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    The Color Inversion feature is mainly used to improve the visibility of text and images on your TV. It inverts the brightness of colors on the screen, meaning that bright areas become dark, and dark areas become bright. This feature can be turned on or off as needed.
    Example of the screen before and after enabling Color Inversion
    1. On the remote control, press the Quick Settings (spanner or gear) button.
    2. Select Settings.
    3. The next steps will depend on your TV menu options:
      • Select Accessibility → Colour inversion → Enable.
      • Select System → Accessibility → Color inversion → Enable.
