The Picture settings allow you to adjust different color, contrast, motion, and brightness settings to improve the content you see on your TV.
The Picture settings may differ depending on your TV model. Choose your TV model type from the items below:
Note: To verify your TV type, refer to the article: How to check if your BRAVIA TV is a Google TV™, Android TV™, or other TV.
Google TV models
To change the Picture settings:
- On the remote control, press the Quick Settings (
or
) button, then select Settings → Display & Sound.
- The next steps will depend on your TV menu options:
- Select Picture & Sound → Picture. Choose your desired option, then click the item you want to change.
- Select Picture. Choose your desired option, then click the item you want to change.
- You can adjust the settings based on what you are watching (e.g. streaming video, DVDs/Blu-ray Discs, content from a USB drive).
- A brief description of each item is displayed on the picture setting screen of your TV. Using this article as supplementary information, you can easily change the settings.
- You can adjust the Picture settings while watching content on the TV screen.
- Available settings items vary by TV model. Some settings may not be available on your TV.
- When Auto Picture Mode is set to On, the Picture mode will change automatically according to the content.
- You may notice a sudden change in the brightness or saturation settings.
- If you don't want the settings to change automatically, turn Auto Picture Mode to Off.
Picture mode
Picture mode is an image quality setting that adjusts the content based on the program genre and image type.
The following are explanations for each of the settings available in Picture mode:
Hint: You can quickly access Picture mode directly by pressing the Quick Settings ( or
) button on the remote control.
Picture mode |
Description |
| Vivid |
Displays clear and enhanced colors, contours, and edges.
| Standard |
Features a high color depth and enhanced edges.
| Cinema |
Balances the brightness, color depth, and edges.
| Professional |
Preserves the original quality of the content.
| Calm |
Produces soft colors and a gentle contrast.
| Game |
Optimizes picture quality and minimizes image delay (the time it takes for the action performed on the game controller to appear on the TV screen).
| Graphics |
Properly displays content graphics (e.g. characters, objects).
| Photo |
Enhances the brightness, color depth, and edges of photos.
| Custom |
Customizes the picture settings.
| IMAX Enhanced |
Displays IMAX Enhanced content as intended.
- The availability of adjustable functions depends on your TV model.
- By selecting Reset picture settings for ***, you can reset the picture settings for the current picture mode to the factory default.
Auto Picture Mode
Automatically selects the Picture mode based on the content you are watching.
Setting |
Description |
| Auto Picture Mode |
Light sensor
Optimizes the screen brightness according to ambient light.
Setting |
Description |
| Light sensor |
Automatically adjusts the picture quality based on the color and brightness of ambient light.
| Auto luminance level |
Adjusts the screen luminance (brightness) level based on the ambient light to reduce glare.
| Auto tone curve |
Adjusts the balance between light and dark in the picture, making it easier to see dark areas of the screen even in a bright room.
Auto white balance (only for specific models) |
Optimizes the color temperature based on the current ambient light.
Brightness
Adjusts the backlight to display the brightest whites and deepest blacks of the image.
Note: The availability of adjustable Setting options depends on your TV model.
Setting |
Description |
| Brightness |
Adjusts the luminance (brightness) of the screen.
| Contrast |
Adjusts the brightness by controlling the signal range.
| Gamma |
Adjusts the light and dark balance by controlling the middle range luminance (brightness) of the screen while maintaining the white and black levels.
| HDR tone mapping |
Automatically adjusts the brightness and gradation balance based on the luminance level of the HDR content.
| Black level |
Adjusts the picture's black level by controlling the signal level.
| Black adjust |
Enhances the black parts of the image by analyzing the picture's brightness level in real time and automatically adjusting the dark levels.
| Adv. Contrast enhancer |
Automatically corrects the contrast of the image by analyzing the picture's luminance level in real time.
| Black equalizer | Enhances the black areas of the screen by analyzing the picture's brightness level in real time and automatically adjusting the dark levels.
| Auto local dimming |
Optimizes the contrast by analyzing the picture's luminance levels in real time and automatically adjusting the backlight brightness.
| Backlight lighting mode |
This features is available only on RGB LED models.
| Peak Luminance |
Optimizes the contrast (especially in dark scenes) by analyzing the screen's luminance levels in real time and making bright areas brighter. Setting values: Off, Low, Medium, or High |
Color
Adjusts the color saturation level and hue.
Setting |
Description |
| Color |
Adjusts the color tone by controlling the color saturation level.
| Hue |
Shifts the overall color (hue) in the red (R) and green (G) direction.
| Color temperature |
Adjust the color temperature that is standard for color reproduction.
| Live Color |
Adjusts the vividness of colors by correcting and expanding the strength of each color.
| Adv. Color temperature: Basic |
Sets the advanced color temperature.
Note: No adjustments needed for normal use. |
| Adv. Color temperature: Multi Point [10p]: |
This function is for advanced users and requires professional picture calibration tools. There are 10 adjustment points available to alter pixel drive at 10 input signal levels.
Note: Only for professional use. During adjustment, picture calibration tools are required. |
| Per color adjustment |
Adjusts the hue, saturation, and lightness for each color.
Clarity
Adjusts the picture clarity and reduces roughness.
Setting |
Description |
| Sharpness |
Adjusts the picture by emphasizing the edges and details of objects and people in the image, as well as controlling noise balance.
| Reality Creation / Resolution |
Enhances the video details by performing Super Resolution processing and noise reduction while analyzing the picture in real time.
| Random noise reduction |
Reduces the dot and color noise that tend to appear in dark areas of the screen.
Digital noise reduction |
Reduces compression noise (e.g. block noise) and noise around letters.
| Smooth gradation |
Creates smooth gradations on flat areas of the picture.
Motion
Refines moving images and optimizes picture quality based on video content.
Setting |
Description |
| Motionflow |
Adjusts the Smoothness and Clearness according to your preferences.
| Motion blur reduction | Adjusts the strength of clarity by inserting a black frame to reduce motion blur.
Film Mode*(GB), CineMotion*(US) |
Reproduces the motion of film content such as movies (images shot at 24 frames per second).
*This item's name varies by region or area.
Android TV models
To access the settings, refer to one of the following methods, depending on your remote control:
- Press the
(Quick Settings) button, then select Settings → Display & Sound → Picture → the desired option.
- Press the ACTION MENU button, then select Picture → the desired option.
- For some TV models, select Advanced settings in Picture to select the detailed options for Brightness, Color, Clarity, and Motion.
- You can adjust your picture settings in real time.
Picture mode
Basic settings are automatically selected based on the mode you choose.
Notes:- You can quickly access Picture mode directly by pressing the
(Quick Settings) button on the remote control.
Picture mode |
Description |
| Vivid |
| Standard |
| Custom |
| Cinema pro (Cinema1) |
Reproduces the content as intended by the film studio.
| Cinema, Cinema home (Cinema2) |
Adjusts the brightness and color of movie content.
| Sports |
Effectively displays fast-moving pictures (sports scenes).
| Animation |
Optimally adjusts animated scenes (e.g. emphasizing cartoon outlines).
| Photo-Vivid |
Enhances the edges and contrast of bright and dark colors.
| Photo, Photo-Standard |
Enhances the photo's brightness, color depth, and edges.
| Photo-Custom |
Customizes the photo settings.
| Game |
| Graphics |
Auto Picture Mode
Setting |
Description |
| Auto Picture Mode |
Automatically selects the Picture mode based on what you are watching on TV.
Light sensor
Setting |
Description |
| Light sensor |
Adjusts the screen's luminance level according to the surrounding brightness.
Brightness
Note: You can quickly access Brightness directly by pressing the (Quick Settings) button on the remote control.
Setting |
Description |
| Brightness |
| Contrast |
Adjusts the white level of the picture.
| Gamma |
Adjusts the light and dark balance.
| Black level |
Adjusts the black level of the picture.
| Black adjust |
Enhances the black parts of the image for stronger contrast.
| Adv. contrast enhancer |
Automatically adjusts the contrast based on picture brightness.
Optimizes the contrast by adjusting the brightness in individual sections of the screen.
| X-tended Dynamic Range |
Adjusts the peak luminance (brightness) level to display the brightest whites and deepest blacks of the image.
Color
Adjust the color saturation level and hue.
Setting |
Description |
| Color |
Adjusts the color saturation level.
| Hue |
Adjusts the color tone.
| Color temperature |
Adjusts the color temperature.
| Live Color |
Emphasizes the vividness of colors.
Clarity
Setting |
Description |
| Sharpness |
Adjusts the picture details.
| Reality Creation/Resolution |
Adjusts the resolution and noise for a realistic picture.
| Mastered in 4K |
Optimizes the picture quality for Blu-ray discs mastered in 4K. Applies to 1080/24p signals only.
Reduces repetitive random noise.
Reduces video compression noise.
| Smooth gradation |
Motion
Enhances moving images and picture quality based on video content.
Setting |
Description |
| Motionflow |
Refines moving images.
Detects the type of videos (such as movies and CG) and performs the best video correction process.
Other TV models
To access the Picture settings:
- On the remote control, press the HOME button, then select Settings → System Settings or Display → Picture.
Note: The availability of the adjustable setting depends on your TV model.
Setting |
Description |
| Picture Mode |
Sets a picture mode. |
| Reset |
Resets all Picture settings to the default settings, except for Picture Mode and Intelligent Picture Plus. |
| Brightness |
Brightens or darkens the picture. |
| Backlight |
Adjusts the backlight luminance.
| Picture/Contrast |
Adjusts the picture contrast. |
| Black level |
Adjusts the black level of the picture. |
| Color |
Adjusts the color saturation level. |
| Hue |
Adjusts the green and red tones. |
| Color Temperature |
Adjusts the color temperature or the whiteness of the picture. |
| Sharpness |
Adjusts the picture details. |
| Reality Creation |
| Mastered in 4K |
Optimizes the picture quality for Blu-ray Discs mastered in 4K. Applies to 1080/24p signals only. |
| Noise Reduction |
Reduces the picture noise (grainy picture) in a weak broadcast signal. |
Reduces repetitive random noise. |
| MPEG Noise Reduction |
Reduces the picture noise in MPEG-compressed videos. |
Reduces video compression noise. |
| Motionflow |
Refines moving images. |
| CineMotion/Cinema Drive/Film |
Improves picture movement when playing content from Blu-ray Discs, DVDs, or VCRs.
Note: If the image contains too much noise, CineMotion/Cinema Drive/Film mode automatically turns off even if Auto is selected. |
| Advanced Settings |
Allows you to set detailed Picture settings such as Gamma or Live Color. |
| Intelligent Picture Plus Set-up |
If you're experiencing picture issues and adjusting the settings above didn't help, refer to this support article: How to troubleshoot TV picture and screen issues.
Please accept Youtube cookies to watch this video
Access your cookie preferences below and make sure to switch on the Youtube cookie under the 'Functional' section.
Register your product
Get access to all information, keep your product up to date and enjoy great deals
Sony Community
Visit our Community and share your experiences and solutions with other Sony customers
Contact support
Contact your Sony Support team
Repair, Warranty & Spare Parts
Book, track or maybe even avoid a repair
