Article ID : 00173738 / Last Modified : 16/01/2026Print
    The image on my TV screen sometimes shifts (Pixel shift function)
    An image shift on your OLED TV is due to a function setting called Pixel shift. This function shifts the image after a certain amount of time to prevent image retention on the screen in order to prolong the life of the display panel. It's recommended that the Pixel shift function is set to On.
    Steps to enable Pixel shift
    Follow the steps below to enable the Pixel shift function:
    1. Open the  Settings screen.
    2. The next steps will depend on your TV menu options
      • Select Display & SoundExpert panel settingsPixel shift → set it to ON.
      • Select Display Expert panel settingsPixel shift → set it to ON.
