Article ID : 00345884 / Last Modified : 28/05/2026Print
    How to output sound from the TV speakers and Bluetooth headphones simultaneously
    IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article for details.
    You can play audio through your TV speakers or audio system and your Bluetooth headphones or other audio device at the same time.
    This is useful if you want to listen to loud audio without disturbing others, such as family members.
    How to set the audio output for Bluetooth headphones or other devices
    1. On the remote control, press the (Quick Settings) button.
    2. Select Audio outputBluetooth device.
    3. Select the Bluetooth audio device that is connected to your TV.
    Note: You can pair your TV and Bluetooth audio devices from the following menu: Select Quick settingsSettingsRemotes and accessories.
