Article ID : 00061343 / Last Modified : 24/02/2020Print
    Wall mounting - What are the VESA dimensions of my TV (2009-2016 models)
    Instead of putting your TV on a piece of furniture, you may want to hang it to the wall. In that case, you will need a wall mount.
    Look for the four mounting holes on the back of your TV. Take both a horizontal (A) and vertical measurement (B), in mm. These are your VESA dimensions, as shown in the tables below.
    Bravia 2016 models
    BRAVIA 2016 Models
     For instructions on using a Sony Wall-Mount Bracket, please refer to the "Wall-Mount Bracket Installation Guide" leaflet supplied with the wall-mount bracket.
    Model A (mm) B (mm) Note
     KDL-
     32RD43x
     40RD45x
     200  200
                       Compatible Sony Wall Mount Bracket: SU-WL450 (Optional).
     KDL-
     32WD60x
     40WD65x
     48WD65x
     200  200
     KDL-
     32WD75x
     43WD75x
     49WD75x
     300  200
     KD-
     49XD700x
     55XD700x
     200  200
     KD-
     65XD750x
     300  300
     KD-
     43XD80xx
     100  200
     KD-
     49XD80xx
     200  300
     KD-
     55XD8005
     200  200
     KD-
     43XD8305
     100  200
     KD-
     49XD8305
     200  300
     KD-
     55XD85xx
     200
     200
     KD-
     65XD85xx
     300  300
     KD-
     75XD850x
     85XD850x
     400  300
     KD-
     50SD8005
     200  200
     KD-
     55SD8505
     200
     200
     KD-
     65SD8505
     300  200
     KD-
     55XD9305
     65XD9305
     300  200
    Sony Wall-Mount Bracket supplied with the TV.
    For more information see the following PDF: Wall-Mount Bracket Installation Guide.
     KD-
     75XD9405
     400  300
     KD-
     65ZD9
     400  300
     KD-
     75ZD9
     400  300
    Bravia 2015 models
    BRAVIA 2015 Models
     For instructions on using a Sony Wall-Mount Bracket, please refer to the "Wall-Mount Bracket Installation Guide" leaflet supplied with the wall-mount bracket. The Wall-Mount Bracket Installation Guide is also available in your local language from downloadable manuals on this support page.
    You can also find the guide for your product by:
    • Selecting your product > Selecting [Manuals] tab > [View all available manuals] > and then choosing the guide for wall-mount bracket installation
    KDL-
    32R40xC
    32R45xC
    40R45xC
    32R50xC
    40R55xC
    48R55xC
    200 200
    KD-43X8305C 200 300
    KDL-
    32W705C
    40W705C
    48W705C
    300 200
    KD-
    49X8305C
    55X8505C
    55X9005C
    65X9005C
    55X9305C
    300 300
    KDL-
    43W755C
    50W755C
    55W755C
    43W805C
    50W805C
    55W805C
    65W855C
    75W855C
    KD-
    65X8505C
    75X8505C
    65X9305C
    75X9405C
    400 300
     KD-
    55X9000C
    65X9000C
    55X9005C
    65X9005C
         You can use your TV's stand as part of the Wall-Mount Bracket (parts supplied with the set).
    You can also refer to the following video: Sony BRAVIA - How to hang your X90C series on the wall
    Bravia 2014 models
    BRAVIA 2014 Models
    KDL-
    32W70xB
    42W70xB
    42W80xB
    42W81xB
    42W82xB
    50W70xB
    50W80xB
    50W81xB
    50W82xB
    200 100
    For instructions on using a Sony Wall-Mount Bracket, please refer to the “Wall-Mount Bracket Installation Guide” leaflet supplied with the wall-mount bracket. The Wall-Mount Bracket Installation Guide is also available in your local language from downloadable manuals in this support page.
    VESA adapter (Sony SUWA1) (Accessory, not supplied with TV) is required for VESA installation
    Note: Insert CAM and Smart card to TV before installing the VESA adapter to TV.
    Vesa Adapter
    KDL-32R41xB
    32R43xB
    40R45xB
    40R48xB
    200 200
    KD-49X8505B
    55X8505B
    55X9005B
    KDL-55W805B
    55W815B
    55W82xB
    55W955B
    60W605B
    60W855B
    200 200
    KDL-
    40W605B
    48W585B
    48W605B
    300 200
    KD-65X8505B
    65X9005B
    79X9005B
    65S9005B
    79S9005B
    KDL-65W955B
    400 300
    KD-
    85X9505B
    400 400
    Bravia 2013 models
    BRAVIA 2013 Models
    KDL-
    24W605A
    N/A N/A
    KDL-24W605A is not VESA compatible.
    KDL-
    32W60xA
    32W65xA
    42W65xA
    50W656A
    50W685A
    200 100
    VESA adapter (Sony SUWA1) (Accessory, not supplied with the TV) is required for VESA installation
    Vesa Adapter
    KDL-32R42xA 100 100
    KDL-40R47xA 200 100
    KDL-46R47xA 300 300 Before installing the Wall-Mount Bracket, attach the Attachment parts for Wall-Mount Bracket (parts supplied with the set) to the rear of the TV, using the supplied screws. Please refer to the instruction manual.
    KDL-40W90xA 200 300
    KDL-42W80xA
    46W90xA
    47W80xA
    55W80xA
    55W90xA
    KD-55X9005A
    300 300
    KDL-65W855A
    KD-65X9005A
    400 300
    Bravia 2012 models
    BRAVIA 2012 Models
    KDL-xxEX440, KDL-xxEX55x, KDL-xxEX65x, KDL-xxHX75x,KDL-xxHX85x, KDL-xxHX95x
    Screen size A (mm) B (mm)
    22" 100 100
    26" 200 100
    32" 200 200
    40"
    46"
    55"
    300 300
    65" 400 300
    Bravia 2011 models
    BRAVIA 2011 Models
    KDL-xxEX310, KDL-xxEX32x, KDL-xxEX42x, KDL-xxEX52x, KDL-xxEX72x, KDL-xxCX52x, KDL-xxNX72x, KDLxxHX72x, KDL-xxHX82x, KDL-xxHX92x
    26" 200 100
    32" 200 200
    40"
    46"
    52"
    55"
    300 300
    60" 400 300
    Bravia 2010 Models
    BRAVIA 2010 Models
    KDL-xxEX30x, KDL-xxEX40x, KDL-xxEX50x, KDL-xxEX60x, KDL-xxEX70x,
    KDL-xxNX50x, KDL-xxNX70x, KDL-xxNX80x, KDL-xxHX70x, KDL-xxHX80x,
    KDL-xxHX90x,
    KDL-xxLX90x
    22" 100 100
    26" 200 100
    32" 200 200
    37"
    40"
    46"
    52"
    300 300
    55"
    65"
    400 300
    Bravia 2009 Models
    BRAVIA 2009 Models
    KDL-xxS5500, KDL-xxS56xx, KDL-xxV5500, KDL-xx V5800, KDL-xxW5500,
    KDL-xxW57xx, KDL-xxW58xx, KDL-xxZ5500, KDL-xxZ5800, KDL-xxE5500,
    KDL-xxS5500, KDL-xxWE5
    26" 200 100
    32" 200 200
    37"
    40"
    46"
    52"
    300 300
