Article ID : 00198426 / Last Modified : 27/06/2019
What apps are available on Sony's Android TV?
    This article will inform you of the following:
    1. What apps are available for Sony's Android TV?
    2. How do I check all of the apps installed on Sony's Android TV?
    1. What apps are available for Sony’s Android TV?
      You can check what apps can be installed on Sony's Android TV from the Google Play Store.
      NOTES:
      • The Google Play Store on Sony's Android TV only displays apps that are supported by the TV, so apps that are not displayed are not supported at the moment. Not all apps for other Android devices (such as smartphones) can be used with the TV.
      • Apps can be purchased through the Google Play Store if you are logged in using your Google ID. You can also install apps you have already installed and paid for on your Android mobile devices for free if there is an equivalent on Sony's Android TV.
        There are two ways to determine what apps are available:
        1. Check the HOME Menu of your TV
          If you already own Sony's Android TV, you can select the Google Play store app from the Apps menu. You can then search through all of the listed apps.
          * Your Home screen may differ depending on the models, regions and apps available.
        2. Check using a computer, tablet, or smartphone
          Using a computer, tablet, or smartphone, visit the Apps for Android TV website for a list of the latest apps that are available for Android TV devices.
          NOTE: When visiting the Apps for Android TV website, you can also see the Description and Reviews of the app before downloading.
    2. How do I check all the installed apps on Sony's Android TV?
      1. Press the HOME button on the remote control.
      2. Select Settings.
      3. Select Apps in the TV category.
      4. Check Downloaded apps or System apps.
