Resolution and aspect ratio are terms used to describe the format and image you see on your television screen. In a television, these two values are related and one affects the other.
Resolution
The resolution defines the number of pixels (dots) that make up the picture on your television. For any given screen size, the more dots in the picture, the higher the resolution and the higher the overall quality of the picture.
TV resolution is often stated as the number of pixels or dots contained vertically in the picture. Each of these resolutions also has a name associated with it.
[A] Resolution (# of vertical dots)
Aspect Ratio
Closely tied to resolution is the Aspect Ratio. This is the ratio of width to height of the TV screen. Certain aspect ratios are designed to handle certain resolutions without any stretching or distortion of the picture and without any blank space around the picture.
[A] Height
[B]Width
Common examples for TVs
Resolution |
Description |
Aspect Ratio |
Width (in pixels) |
Height (in pixels) |
480i or 480p | Standard Definition (SD) |
4:3 |
640 |
480 |
720p | High Definition (HD) |
16:9 |
1280 |
720 |
1080i or 1080p | High Definition (HD) |
16:9 |
1920 |
1080 |
2160p | Ultra High Definition (UHD) or 4K |
16:9 |
3840 |
2160 |
