Article ID : 00107503 / Last Modified : 12/07/2018Print
    How to format using a PC a USB HDD previously used with TV
    The procedure differs depending on Operating System installed your PC.
    Procedure for Windows XP
    Procedure for Windows Vista, 7, 8, 8.1
    Procedure for Mac
    WARNING: There is a risk of data loss.
    If you format the USB HDD all the recorded contents will be deleted and cannot be recovered.
    Procedure for Windows XP:
    Preparation: Please verify below points before performing the HDD format.
    1. Remove all the USB storage devices from your PC
    2. Log in your PC as an Administrator
    3. If you are using laptop, Plug in to AC
    4. Format may take couple of hours; keep the power supply connected during HDD formatting.
    Change the settings to [None] for the [Hard disk] and [System Standby] from [Power management].
    Right click on the desktop > [Properties] > [Screen sever] > [Power management] > [System standby] and [Hard disk]
    1. Right click [My computer], then click [Management] from menu
    Otherwise you can access to [Management] as follow:
    [Start] > [Setting] > [Control panel] > [Administrative tools] > [Computer management].
     2. Select [Disk management] in the below menu
    3. Connect the USB HDD to the USB port.
    After connection the USB HDD will appear in the screen. Please make sure is the right HDD connecting and disconnecting from USB port.
    4. Select the partition of your HDD.
    5. Delete all the partitions of the HDD, clicking the right button over the partition and select [Delete partition] from menu.
    6. You will be asked to confirm if you want to delete the partition. Select “Yes"
    7. Proceed in the same way with the rest of partitions of the HDD
    8. When all the partition have been deleted. Click right button and select [New partition] from menu
    9. The below screen “New Partition Wizard” will appear.
    10. Select “Next”
    11. Select [Primary partition] and "Next"
    12. Leave the options by default and click on "Next"
    14. In the below screen, select option [Format this partition] with settings by default.
    NOTE: HDD formatting takes a couple of hours depending on combination of your HDD capacity and CPU of PC.
    Regular or Quick format?
    Q
    uick Format: Removes files from the disk without scanning the disk for bad sectors. Use this option only if the disk has been previously formatted, and you are sure the disk is not damaged.
    Regular Format: files are removed from the volume that you are formatting and the hard disk is scanned for bad sectors. The scan for bad sectors is responsible for the majority of the time that it takes to format a volume.
     Regular format  Quick format
     Image  Image
    15. Click on “Finish
    16. You can show File allocation system as [NTFS] after completed HDD format.
    17. Double click [My computer], then your formatted HDD will be shown
    Procedure for Windows Vista, 7 and 8: Preparation:
    2. Log in in your PC as an Administrator
    1. Right-click [Computer icon] on Desktop or Start menu and click [Manage]
    1. Alternative method to access to [Manage] is:
    1. Click on the [Start] button and then choose [Control Panel].
      *Point cursor lower right corner of screen, and select [Settings]. Select [Control Menu] from Settings menu.
      *Windows 8 Only
    2. Click on the [System and Security] link.
      NOTE: If you're viewing the Large icons or Small icons view of Control Panel you won't see this link so just click on the Administrative Tools icon and skip to Step 4.
    3. In the System and Security window, click on the [Administrative Tools].
    4. In the Administrative Tools window, double-click on the [Computer Management] icon.
    5. When Computer Management opens, click on [Disk Management]on the left side of the window, located under Storage.
    2. Computer Management window opens Click Disk Management on the left side, under Storage section
    3. Disk Management window opens. The HDD appears in the screen, but without [File System] information Please make sure is the right HDD connecting and disconnecting from USB port
    4. Delete all the partitions of the HDD, clicking the right button over the partition and select [Delete Volume] from menu
    5. You will be asked to confirm if you want to delete the partition. Select [Yes]
    6. Proceed in the same way with the remaining partitions of the HDD
    7. When all the partition have been deleted. Click right button and select [New simple Volume] from menu.
    8. New Simple Volume Wizard window opens.
    9. Select [Next].
    10. Keep the default value and click on [Next].
    11. If needed, assign a drive letter to the partition and click on [Next].
    12 .Select option [Format this volume with the following settings]. Leave the settings by default and click on [Next].
    13 .Click on [Finish].
    14.You can seen File allocation system as NTFS after completed HDD format.
    15. Double click Computer icon, then your formatted HDD will be shown For [Windows 8].
     Right click on Start screen, and select [All apps] > [Computer].
    Procedure for MAC (10.6): Preparation:
    Please verify the below points before performing the HDD format.
    2. If you are using laptop, Plug in to AC
    3. Format may take some minutes, so keep the power supply connected during HDD formatting.
    1. If you have used the HDD with your Bravia TV to record, when you connect the HDD disk to the USB port of computer will appear automatically the following message on the screen
    2. The [Disk Utility] screen will appear.
    Otherwise you can access to [Disk Utility] through [spotlight] on the upper right side of the desktop; writing [disk utility] and click on it.
    3. In the left side of the [Disk Utility] will appear all storage devices connected to your MAC.
    Please make sure to select the HDD to be formatted (if HDD was used with BRAVIA you will see 5 partitions, for example: disk1sx)
    4. Click over the correct HDD, and will appear the below screen with indications
    5. Select [Erase] in the below screen will appear
    6. Click on the down arrow (red circle) to select the desired [Format]
    7. Optionally give a name to the HDD
    8. Click [Erase] in the bottom right side of screen
    9. A message will appear to confirm if you want to erase the HDD. Please select [Erase].
    10. The formatted HDD will be shown
    11. Now when connecting the HDD disk to the USB port it will be recognized and the icon will appear on the desktop
    Applicable models
    KDL-22EX320
    KDL-22EX325
    KDL-24EX320
    KDL-24EX325
    KDL-26EX320
    KDL-26EX321
    KDL-26EX325
    KDL-32CX520
    KDL-32CX521
    KDL-32CX523
    KDL-32CX525
    KDL-32EX421
    KDL-32EX424
    KDL-32EX425
    KDL-32EX520
    KDL-32EX521
    KDL-32EX523
    KDL-32EX524
    KDL-32EX525
    KDL-32EX720
    KDL-32EX721
    KDL-32EX723
    KDL-32EX724
    KDL-32EX725
    KDL-32EX726
    KDL-32EX727
    KDL-32EX728
    KDL-32EX729
    KDL-37EX521
    KDL-37EX524
    KDL-37EX525
    KDL-37EX720
    KDL-37EX725
    KDL-40CX520
    KDL-40CX521
    KDL-40CX523
    KDL-40CX525
    KDL-40EX520
    KDL-40EX521
    KDL-40EX523
    KDL-40EX524
    KDL-40EX525
    KDL-40EX720
    KDL-40EX721
    KDL-40EX723
    KDL-40EX724
    KDL-40EX725
    KDL-40EX726
    KDL-40EX727
    KDL-40EX728
    KDL-40EX729
    KDL-40HX720
    KDL-40HX723
    KDL-40HX725
    KDL-40NX720
    KDL-40NX723
    KDL-40NX725
    KDL-46CX520
    KDL-46CX525
    KDL-46EX520
    KDL-46EX521
    KDL-46EX524
    KDL-46EX525
    KDL-46EX720
    KDL-46EX721
    KDL-46EX723
    KDL-46EX724
    KDL-46EX725
    KDL-46EX726
    KDL-46EX727
    KDL-46EX728
    KDL-46EX729
    KDL-46HX720
    KDL-46HX723
    KDL-46HX725
    KDL-46HX820
    KDL-46HX823
    KDL-46HX825
    KDL-46HX920
    KDL-46HX923
    KDL-46HX925
    KDL-46NX720
    KDL-46NX723
    KDL-46NX725
    KDL-55EX720
    KDL-55EX721
    KDL-55EX723
    KDL-55EX725
    KDL-55HX820
    KDL-55HX823
    KDL-55HX825
    KDL-55HX920
    KDL-55HX923
    KDL-55HX925
    KDL-55NX720
    KDL-55NX723
    KDL-55NX725
    KDL-60NX720
    KDL-60NX723
    KDL-60NX725
    KDL-65HX920
    KDL-65HX923
    KDL-65HX925
    KDL-22EX550
    KDL-22EX553
    KDL-22EX555
    KDL-26EX550
    KDL-26EX553
    KDL-26EX555
    KDL-32EX650
    KDL-32EX653
    KDL-32EX655
    KDL-32HX750
    KDL-32HX751
    KDL-32HX753
    KDL-32HX755
    KDL-32HX757
    KDL-32HX758
    KDL-32HX759
    KDL-40EX650
    KDL-40EX653
    KDL-40EX655
    KDL-40HX750
    KDL-40HX751
    KDL-40HX753
    KDL-40HX755
    KDL-40HX756
    KDL-40HX757
    KDL-40HX758
    KDL-40HX759
    KDL-40HX75G
    KDL-40HX850
    KDL-40HX853
    KDL-40HX855
    KDL-46EX650
    KDL-46EX653
    KDL-46EX655
    KDL-46HX750
    KDL-46HX751
    KDL-46HX753
    KDL-46HX755
    KDL-46HX756
    KDL-46HX757
    KDL-46HX758
    KDL-46HX759
    KDL-46HX75G
    KDL-46HX850
    KDL-46HX853
    KDL-46HX855
    KDL-55HX750
    KDL-55HX751
    KDL-55HX753
    KDL-55HX755
    KDL-55HX75G
    KDL-55HX850
    KDL-55HX853
    KDL-55HX855
    KDL-55HX950
    KDL-55HX953
    KDL-55HX955
    KDL-65HX950
    KDL-65HX953
    KDL-65HX955
