Article ID : 00161965 / Last Modified : 03/02/2022Print
    How to connect a BRAVIA Internet Video device to a wireless gaming adapter
    NOTES:
    • Not all Blu-ray Disc™ or TVs have Internet capabilities. To see if your Blu-ray Disc player or TV has the functions discussed in this solution, check the specifications.
    • Prior to following the steps in this solution, ensure that there is an active Internet connection and that the modem has been activated.
    1. Connect the gaming adapter to the A/C power.
    2. Disconnect the wireless connection on your computer.
    3. Connect one end of the Ethenet cable into the gaming adapter.
    4. Connect the other end of the Ethernet cable to the network port of the computer.
    5. Turn On the computer.
    6. Open a Web browser and enter the IP address of the gaming adapter into the address bar.
      NOTE: The IP address is supplied by the manufacturer of the gaming adapter.
    7. If prompted, enter the Username and Password.
      NOTE: The username and password is supplied by the manufacturer of the gaming adapter.
    8. Follow the steps that appear on the screen to configure the wireless settings.
      NOTE: Further information should be available in the set up guide supplied with the gaming adapter.
    9. Once the wireless setup is complete, unplug the Ethernet cable from the computer and connect it to the LAN connection on the BRAVIA Internet Video (BIV) device.Image
