Article ID : 00081196 / Last Modified : 10/02/2026Print
    How to use the Wi-Fi Direct feature on a BRAVIA TV
    Wi-Fi Direct allows you to wirelessly connect a device to the TV without using a wireless router, and then stream videos, photos, and music from that device directly to the TV.
    Note: For other wireless connection methods refer to the following articles:
    Before you start
    • Make sure your TV software is updated to the latest version.
    • Depending on your TV model, the device that you are using, or regions/countries, some functions may not be available.
    • Not all TVs have the Wi-Fi Direct feature. To see if your product supports the Wi-Fi Direct feature, check the specifications or the supplied manual.
    • For more details regarding the Wi-Fi Direct feature, refer to the article What is the Wi-Fi Direct feature?
    Set up and use the Wi-Fi Direct feature
    Activate the Wi-Fi Direct mode on the TV and establish a connection with the device. Once the setup is complete, media can be shared between the device and the TV.
    Step1. Set up the Wi-Fi Direct feature of the TV
    Note: For your TV model, refer to the article How to check if your BRAVIA TV is a Google TV™, Android TV™, or other TV.
    Step 2. Connect a device to the TV and send content.
    Troubleshooting
    If the device cannot connect to the TV, refer to the article The Wi-Fi Direct or Screen mirroring function doesn't work.
    If the issue is not resolved, or the connection is unstable, try one of these alternative methods:
    * Apple, iPhone, and iPad are trademarks of Apple Inc., registered in the U.S. and other countries and regions.
