Article ID : 00141385 / Last Modified : 16/01/2026Print
    When using Photo Frame Mode, the TV does not enter Standby mode, even after the time set for Idle TV Standby has passed.
    If the initial settings for Photo Frame Mode are not adjusted, the TV will enter Standby mode after 24 hours have passed. To change the duration setting, follow the steps below.
    1. Press the HOME button on the remote.
    2. Select Settings, then press the Enter button.
    3. Select System Settings, then press the Enter button.
    4. Select Set-up, then press the Enter button.
    5. Select Photo Frame Settings, then press the Enter button.
    6. Select Duration, then press the Enter button.
    7. Select the desired time.
