Article ID : 00115089 / Last Modified : 12/07/2018
How can I play content from my computer on my television?
    There are various ways for you to connect your computer to your TV, in order to enjoy music, videos, games and more on the TV's bigger screen. The easiest way to do this is by using a cable, which is described here below, but you can also do it wirelessly, using Wi-Fi Direct .
    Connecting your Windows computer to your TV using a cable
    Configuring your Windows computer to optimise video settings and use the TV speakers
    Connecting your Mac OS computer to your TV using a cable
    Configuring your Mac OS computer to optimise video settings and use the TV speakers
    Connecting your Windows computer to your TV using a cable:
    According to your TV and computer models, the cable you will need to use might differ. Modern devices use HDMI connectors and cables - which will be the example used in this tutorial - but you might need to use older connections such as:
    • DVI
    • VGA
    • S-Video
    • RCA/Composite
    1. Connect your PC to your TV using an HDMI cable. Make sure the cable is securely connected both on your PC and on your TV.
      HDMI connection
      NOTE: Make sure to use an authorised HIGH SPEED HDMI cable bearing the HDMI logo.
    2. Press theInput buttonbutton on your remote repeatedly to select the HDMI input corresponding to the connected computer.
      Input button remote
    Your TV should now be displaying your computer screen.
    • Video settings
    1. Right-click any blank part of your desktop and select Screen Resolution.
    2. In the menu Screen Resolution menu, you should see 2 screens displayed.
      Display settings
      Select the TV screen (likely to be the larger one), and use the highest option available. If the result is not satisfactory, you can try lower resolution settings.
      NOTE: The available options will vary according to your computer and TV. Make sure to select a resolution with an aspect ratio matching your TV format - usually 16:9. Common 16:9 resolutions are 1920x1080, 1600x900, 1366x768 and 1280x720.
    3. Set Multiple displays to Duplicate these displays to mirror the screens, or tick the Make this my main display box to use the TV's potentially higher resolutions, according to your computer and TV specifications.
    • Audio settings
    Unless you are intentionally using some external speakers for your computer, you will likely want the sound to be output by your TV's speakers. Here is how to do it:
    1. Right-click the Volume mixer, represented by a speaker icon in the system tray, and select "Playback devices."
      Speaker icon
    2. Right-click on your Television in the list of devices, and select "Set as Default Device."
    3. Finally, click "Apply", then "OK."
    You should now hear the sound output from your computer through your TV speakers.
    NOTE: If you still do not hear sound from your TV speakers, your HDMI cable is probably damaged or does not support audio. Make sure to use an authorised HIGH SPEED HDMI cable bearing the HDMI logo.
    If you are using a Mac computer, make sure you have the following items:
    • Mac OS computer equipped with a Mini-DisplayPort or Thunderbolt port
    • Mini DisplayPort/Thunderbolt to HDMI Adaptor with Audio Support
    • HDMI cable
    1. Plug your HDMI Adaptor to your Mini DisplayPort/Thunderbolt port on your Mac computer
       Thunderbolt port  Mini DisplayPort
    2. Connect the HDMI cable to the adaptor, and the other end to a HDMI port on the TV
    3. Press theInput buttonbutton on your remote repeatedly to select the HDMI input corresponding to the connected computer.
      Input button remote
    • Video settings
    You can either simply mirror the display from your computer to your TV, or choose to set the TV as the primary display.
    To set up mirroring, proceed as follows:
    1. Open System Preferences from the Apple menu
    2. Select Displays, and click on the Arrangements tab
    3. Check the Mirror Displays box
    While this usually looks great on a 720p TV screen, it’s not always the case for 1080p TVs. Since the 1080p resolution is greater than what is often found on Mac displays, you might want to set the TV as the primary display instead. To do so:
    3. Drag the white bar from the smaller computer screen to the external TV display
      Drag menu bar
    • Audio settings
    2. Select Sound, and click on the Output tab
    3. Select your TV / the device for which HDMI is displayed in the Type column
    NOTE: If you still do not hear sound from your TV speakers, your HDMI cable or adapter is probably damaged or does not support audio. Make sure to use an authorised HIGH SPEED HDMI cable bearing the HDMI logo.
