When the PlayStation 5 is connected to your Android TV or Google TV, the Auto Low Latency Mode (ALLM) function is engaged, and the TV will automatically switch the Picture mode to Game mode and keep it in Game mode until the ALLM function is disabled.
If you want to adjust the brightness or picture parameters, follow these steps:
- On the remote control, press the
(Quick Settings) button.
- Select Picture settings, and then you can adjust the parameters (brightness, contrast, colour intensity) while Picture mode is set to Game.
Note: Once ALLM is disabled on PS5, the picture mode setting of the TV will return to normal mode (Standard, etc.). There will no longer be a restriction to Game mode.
If you want to see PS5 content without ALLM, update the PS5 System Software to the latest version (later than the July 7th, 2022 update). After this update, you can change the ALLM setting on the PS5 to OFF by going to the PS5 Setting → Screen and Video → Video Output → ALLM.
Notes:
- For information on the PlayStation System Software Update, refer to the PS5 support page.
- If you change the ALLM setting of the PS5 to OFF, you can change the Picture mode of the BRAVIA TV to something other than Game while viewing PS5 content.
