Article ID : 00174098 / Last Modified : 10/02/2026Print
How to prevent sudden volume changes on your TV when switching TV channels, apps, or external inputs
    If you are troubled by sudden volume changes and constant manual adjustments while watching TV, the Advanced auto volume or Volume offset feature will adjust the volume level of broadcasts and external inputs, ensuring a comfortable and seamless TV viewing experience.
    • Advanced auto volume: Adjusts all volume levels automatically.
    • Volume offset: Adjusts the volume individually for TV broadcasts and connected external devices. (Not supported with the A95L series and models from 2024 onward.)
    You can set the Advanced auto volume or Volume offset feature via the Sound or Sound adjustments option.
    We recommend using these features if:
    • You are bothered by sudden changes in volume, such as unexpectedly loud sounds.
    • You often adjust the volume with the remote control when switching channels, apps, or each external input.
    Note: Not all TVs listed under Applicable Products have the Advanced auto volume or Volume offset feature. To see if your TV has these features, check the specifications. Manuals are posted on your model support page.
