Article ID : 00157047 / Last Modified : 10/02/2026Print
How to add or remove a Google account on a Sony's Google TV™ or Android TV™
    Managing your Google™ account on Sony's Android TV™ or Google TV™ is easy, whether you're adding a new profile or removing an existing one. This guide provides step-by-step instructions and troubleshooting tips so everyone can access their favorite apps and services.
    On this page
    Before you start
    Menu names or screen layouts may vary depending on your TV model and software version. For model-specific instructions, refer to your TV's Help Guide .
    Add a Google account
    If you're signing in for the first time or want to add another account, follow these steps.
    1. Open Settings
      Press the Quick Settings ( or ) or HOME button on the TV remote, then select Settings.
    2. Go to Accounts
      Depending on your TV’s software version, the menu labels may differ slightly. Choose the option that most closely matches your TV menu.
      • Select Accounts & Sign InAdd accountSign In.
      • Select Accounts & Sign InAdd another accountGoogle.
      • Select Accounts & Sign InAdd accountGoogle.
      • Select Add account.
    3. Enter your email
      Enter the email address, then select NEXT.
      Note: Use the Arrow buttons on the remote control to use the on-screen keyboard and press the enter button to select characters.
    4. Enter your password
      Enter the Password, then select NEXT to complete sign-in.
      After you have successfully signed in, your Google Account will appear in the Accounts list.
    When you have multiple Google accounts added to your TV, different members of your household can access their own streaming apps, personalized recommendations, and services tied to their Google profiles.
    Remove a Google account
    You can remove a Google account from your TV at any time.
    1. Open Settings
    2. Select Accounts
      Select Accounts & Sign in.
    3. Choose the account to remove
      • If multiple accounts are signed in:
        The selected account is removed, and you can continue using the TV with the remaining account(s).
      • If only one account is signed in:
        Removing it may require the TV to reset to factory default settings, which can delete apps and personal settings. You must either:
        • Add a new Google account first, or
        • Proceed with the factory reset.
      Select the Google account you want to remove.
    4. Remove the account
      1. Select Remove.
      2. If prompted, select Remove and reset device.
      3. After the reset completes, follow the on-screen instructions to:
        • Set up Google TV (sign in with a different Google account), or
        • Set up basic TV (no Google account).
    For Android 6.0 or earlier
    To register a different account, delete the registration information for your current account, and then add a different account.
    1. Delete the registration information for your current account
      1. Press the HOME button on the remote control.
      2. Select Settings.
      3. Select Google in the Personal category.
      4. Select Remove account.
      5. Select OK.
    2. Register a different Google account
      2. Select Settings.
      3. Select Add account in the Personal category.
      4. Select SIGN IN.
    Troubleshooting tips
    If you're having trouble adding or removing a Google account on your TV, try these solutions.
    I can't sign in to my Google account
    • Make sure your TV is connected to the internet.
    • Check that you’re entering the correct email address and password.
    • If you use 2-step verification, complete the verification prompt on your phone or computer.
    • Restart your TV and try again.
    • If the issue continues, try signing in on another device to confirm the account works.
    I don't see the "Accounts & Sign In" or "Add account" option
    • Menu names may differ by TV model and software version.
    • Look for similar options such as Accounts, Users & Accounts, or Add another account.
    • If the menu still doesn't appear, check your TV's Help Guide for model-specific instructions.
    I can't remove a Google account
    • Make sure you select the correct account under Accounts & Sign In.
    • If it’s the only account signed in, you’ll need to sign in with a new Google account or use Basic TV mode.
