Article ID : 00251057 / Last Modified : 20/01/2026Print
    Text Magnification for XH74 and XH75 series Android TV
    The Text magnification function is useful for people who have difficulty reading text on the TV screen because the text is too small to read.
    Enabling text magnification
    1. Press the HOME button on the remote control.
    2. Since Settings icon is located on the upper right corner of the Home menu, press and hold the Up arrow button for about three seconds and then press and hold the Right arrow button for about two seconds to select Settings then press the Enter button.
    3. Press the Down arrow button to select Device Preferences and press the Enter button.
    4. Press the Down arrow button to select Accessibility and press the Enter button.
    5. Press the Down arrow button to select Text magnification and press the Enter button.
    6. Select Enable then press the Enter button.
    7. Select OK then press the Enter button.
    8. Press the HOME button to exit.
    Changing the colour of the text
    6. Press the Down arrow button to select Configuration and press the Enter button.
    7. Select Color and press the Enter button.
    8. Press the Down arrow button to select your preferred combination of the text and background colour among White on black, Black on white, and Yellow on black then press the Enter button.
    9. Press the HOME button to exit.
