Article ID : 00138119 / Last Modified : 16/01/2026Print
How to show X-Reality Pro & other features in Demo Mode
    Only demos of features that are supported by the TV are selectable.
    How to play Demo content
    1. Turn on Demo Mode.
      1. Press the HOME button on the remote control.
      2. Select  Settings.
      3. The next steps will depend on your TV menu options:
        • Select Device Preferences — Retail mode settings — Demo Mode — set to On(Android™ 9)
        • Select Retail mode settings — Demo Mode — set to On(Android 8.0 or earlier)
    2. Select a procedure below according to the OS version of your TV.
      For Android 9 / Android 8.0
      2. Select  Apps.
      3. Select Demo App.
      4. Use one of the procedures below to start a demo playback.
        • Select Start playback.
        • Select Select Build-in demo pattern and choose the desired demo menu to play.
      For Android 7.0 or earlier
      1. Press the INPUT button on the remote control and switch to a TV broadcast or external input screen.
      2. Press the ACTION MENU on the remote control.
      3. Select Loop Demo or ePOP+Feature Demo. The Loop demo starts.
      4. Press the ACTION MENU on the remote control again.
      5. Select the desired demo menu to play.
    How to turn off Demo mode
    After playback, follow the steps below to set Demo Mode and Picture Reset Mode to Off. When Demo Mode is turned on, Picture Reset Mode turns on automatically. If Picture Reset Mode is on, the image quality settings for storefront displays are maintained, so please turn it off.
    1. Press the Home button on the remote control.
    2. Select  Settings.
      • Select Device Preferences — Retail mode settings(Android 9)
      • Select Retail mode settings(Android 8.0 or earlier)
    4. Select Demo Mode and set to Off.
    5. Select Picture Reset Mode and set to Off.
