The compatibility chart of the 3D glasses for Android TV (2016/2015 models)
- I want to check the compatible optional 3D glasses for my BRAVIA TV.
- I purchase a new 3D supported BRAVIA TV. Can I continue to use the 3D glasses that I am using for my older TV on the new TV?
You will require a compatible 3D glasses for watching 3D movies with 3D supported Android TV (2016/2015 models).
Check the following compatibility chart to confirm which 3D type corresponds to your TV and the compatible 3D glasses for your TV.
2016 models
| 3D function supported BRAVIA TV | 3D type | Communication system | Compatible 3D glasses | |
| Series | Model name | |||
| ZD9 Series | KD-100ZD9 KD-75ZD9 KD-65ZD9 |
Active | RF (Bluetooth) | TDG-BT500A / TDG-BT400A (*1) |
| XD93xx_XD94xx Series | KD-75XD9405 KD-65XD9305 KD-55XD9305 |
2015 models
For AP Region:
| X93xxC_X94xxC Series | KD-75X9400C KD-65X9300C KD-55X9300C |
| X90xxC_X91xxC Series | KD-75X9100C | |||
| KD-65X9000C KD-55X9000C |
Passive | IR | TDG-500P | |
| X85xxC Series | KD-75X8500C KD-65X8500C KD-55X8500C |
| S85xxC Series | KD-65S8500C KD-55S8500C |
| W85xC Series | KDL-75W850C KDL-65W850C |
| W80xC Series | KDL-55W800C KDL-50W800C KDL-43W800C |
*1 Supplied as an accessory depending on the model/region/country
| X90xxC_X91xxC Series | KD-75X9105C | Active | RF (Bluetooth) | TDG-BT500A / TDG-BT400A (*1) |
| KD-65X9005C KD-55X9005C |
| X85xxC Series | KD-65X8508C KD-55X8508C KD-65X8507C KD-55X8507C KD-75X8505C KD-65X8505C KD-55X8505C KD-75X8501C KD-65X8501C KD-55X8501C |
| S85xxC Series | KD-75X9105C | |||
| S80xxC Series | KD-65S8005C KD-55S8005C |
| W85xC Series | KDL-65W859C KDL-65W858C KDL-65W857C KDL-75W855C KDL-65W855C |
| W80xC Series | KDL-55W809C KDL-50W809C KDL-43W809C KDL-55W808C KDL-50W808C KDL-43W808C KDL-55W807C KDL-50W807C KDL-43W807C KDL-55W805C |
