Article ID : 00111120 / Last Modified : 29/01/2025Print
How to manually sort and edit your TV channels
    You can rearrange your TV channels using your remote control, and in some cases your smartphone. Whether you are watching digital, satellite, or analogue channels, we’ll walk you through the steps to update your channel list.
    Note: Keep in mind the steps in this article are only a guide. Visit the Sony Support site for model-specific details.
    Using your remote control
    To manually sort your channel list:
    1. Press the spanner (Quick Settings) button on your remote control.
    2. Select Settings → Channels & Inputs → Channels → Channel list edit.
      If multiple items are displayed, select the one you want to edit.
    3. Select the channel and its new position.
    4. Select Done to apply the changes.
    For some 2019 or older models
    The steps below depend on your channel type and may vary by TV model.
    How to insert, swap, or hide channels
    The steps to edit your channel list will depend on your TV model and menu options.
    Using your smartphone (for certain Android TVs)
    First, you'll need to download the TV Channel Editor for BRAVIA mobile app on your smartphone and connect it to your TV.
    TV Channel Editor for BRAVIA app - Google Play
     TV Channel Editor for BRAVIA - App Store
    Visit this article for exact steps and applicable models: TV Channel Editor for BRAVIA mobile app: edit your TV channel list from your smartphone!.
