Article ID : 00150279 / Last Modified : 16/01/2026Print
How to protect/cancel protection on recorded content
    Please use the following steps below:
    1. Press the HOME button on the remote.
    2. Select Recorded Title List in the Apps category.
    3. Select the content that you want to protect/cancel protection on, and press the ACTION MENU button on the remote.
    4. Select Protect in the Recorded Title List category.
    5. Add a check to the programmes that you want to protect, or remove the check to cancel the protection.
    6. Select Set.
