Article ID : 00124651 / Last Modified : 08/09/2026Print
    How to change the time on my Android TV™/Google TV™ to adjust for Daylight Savings Time (DST)/Summer time?
    Depending on your situation, you can adjust the following settings.
    Note: If there are no broadcast signals or network connections, refer to the If the date and time are manually set section of this article.
    If the date and time are automatically set
    Follow these steps to set the correct time:
    1. Open the Settings screen.
    2. The next steps will depend on your TV menu options:
      • Select SystemDate & time.
      • Select Device PreferencesDate & time.
      • Select Device PreferencesDate & timeTime.
      • Select Date & time.
      • Select Date & timeTime.
      Note: For BRAVIA 2 II (S20), BRAVIA 3 (S30), and BRAVIA 3 II (XR30M2): If your TV has no Internet connection, tune the broadcast signal and then select Date and timeAutomatic date & timeOn.
    3. Select Set time zone, then select the proper city.
      • Select SystemDate & timeAutomatic date & time and set to Off.
      • Select Device PreferencesDate & timeAutomatic date & time and set to Off.
      • Select Date & timeAutomatic date & time and set to Off.
    3. In Date & time, select one of the following menu options:
      • Select Set time zone, then select the proper city.
      • Select TimeSet time zone, then select the proper city.
    4. Go back to Date & time and select one of the following menu options:
      • Select Set time, then set the correct time.
      • Select TimeSet time, then set the correct time.
