Article ID : 00345344 / Last Modified : 28/05/2026Print
    Finding the remote control (only models supplied with a buzzer built-in remote control)
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
    The supplied TV remote control has a feature that allows you to find it by playing a sound from a built-in buzzer.
    Do the following to find the remote control:
    1. Press the Power button on the TV.
    2. On the displayed TV screen menu, follow the on-screen instructions and move the cursor to Find remote.
    3. Press the Power button for more than one second, then select the Find remote option.
    4. The remote control will emit a buzzing sound to help you find it.
    Notes:
    • The Find remote option is only available when the remote control is paired with the TV.
    • There is a limited range within which you can search for the remote control. If the remote is too far away from the TV, the signal will not reach it and the buzzer won't play.
