If you think the sound output from your headphones is strange or distorted, the type of headphone plug might be the reason.
In the pictures below you can see there is a difference between a 3-pole and a 4-pole mini plug.
- Do use a 3-pole stereo mini plug in the AUDIO OUT terminal.
- Don't use a 4-pole stereo mini plug as they are not supported.
