Article ID : 00186768 / Last Modified : 23/07/2026Print
    FAQs for Using Amazon Alexa with BRAVIA TVs
    IMPORTANT: This article only applies to specific products, countries/regions, and/or operating systems. For the applicable products, please check the Applicable Products and Categories section of this article. For the applicable countries/regions and operating systems, please refer to the article Countries and regions where Sony's TV supports Amazon Alexa devices.
    Basic Information
    Alexa is Amazon's cloud-based voice service. Alexa Skills are voice-driven features of the Alexa Cloud Service that allow you to control select products through the Amazon Alexa app and Alexa-enabled devices such as Amazon Echo or Amazon Echo Dot. With this feature, you can use your voice to turn your TV on or off, change channels, control volume, and more.
    If your TV supports Amazon Alexa, one of the following apps will be on the Apps list. You cannot install these apps yourself.
    • TV Control with Smart Speakers
    • TV Control Setup with Amazon Alexa
    For more details, refer to the following:
    Hot Topic
    The TV can suddenly no longer be controlled with Amazon Alexa-enabled devices through voice operations.
    Refer to the article The TV's Voice Control with Amazon Alexa-Enabled Devices suddenly stops working.
    How to Use
    Troubleshooting
    Attributions
    * Amazon, Echo, Alexa, and all related logos are trademarks of Amazon.com, Inc. or its affiliates.
