Article ID : 00348135 / Last Modified : 28/05/2026Print
    Adjusting the sound quality on a Google TV™
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
    You can configure various TV audio settings such as sound quality and sound mode.
    Follow the steps below to access those settings:
    1. On the remote control, press the Quick Settings (spanner or gear) button.
    2. Select Settings.
    3. The next steps will depend on your TV menu options:
      • Display & Sound → Picture & Sound → the desired option (e.g., Picture & Sound or Sound).
      • Display & Sound → the desired option (e.g., Picture & Sound or Sound).
    Note: The actual display may vary, and some settings may not be available depending on your model, country/region, your TV settings, and the connected device.
