Article ID : 00281393 / Last Modified : 28/06/2023Print
Tuning your Sony Google TV (Channel Setup)
    So, you'd like to tune your Sony Google TV and get all your channels set up, but like me, you tend to press the skip button a few too many times when setting up your TV. No problem. You can easily tune your Sony Google TV at any time from the settings menu.
    Transcript:
    How To: Tune your Sony Google TV
    So you'd like to tune your Sony Google TV and get all your channels set up. But like me, you tend to press the skip button a few too many times when setting up your TV. No problem. You can easily tune your Sony Google TV at any time from the settings menu. You can also do this if you need to retune your TV. For example, if your broadcaster changes frequencies and you lose some channels to begin the tuning process, connect to the relevant cable or antenna from your service provider, then simply navigate to settings. Select Channel and inputs channels. Channel set up auto tuning. Select the service that you are using to search for channels. Or if they are listed, you should select your channel provider. Select set up, then select next. You should then, see the TV scanning for channels which will show you a progress bar and will also give you an estimated time for completion. We've sped the process up here, but it can take up to 30 minutes. Once completed, the TV will display how many channels were found. If some channels are missing. It may be because your provider no longer offers them.
    Please check with your provider for further information on specific channels. If you're having any other issues a couple of quick and easy fixes, you can always try are, perform a soft reset on your TV by holding the power button on your remote for 10 seconds. It's always a good idea to try this every so often. If you run into a small issue as it's healthy for your TV to be properly switched off every now and again. You can also update your firmware by navigating to settings > system > about > software update. It's always a good idea to keep your TV on the latest software, which contain all the latest fixes for any issues. If you have any more questions about tuning your Sony Google TV, please visit the Sony support website.
    Thank you for watching.
    This video supports subtitles.
    How to turn captions on or off when watching Internet videos from YouTube.
