Article ID : 00173356 / Last Modified : 10/02/2026Print
    How to hear sound from both your TV speakers and audio devices at the same time (dual audio output)
    It's possible to hear sound from both your TV speakers and audio device (e.g. headphones, soundbar) at the same time. However, the setup procedure depends on your TV model and connection method.
      Before you start
      • Choose your TV model: Refer to this article to help identify your TV type (Google TV, Android TV, or other).
      • Confirm dual audio compatibility: Some TV models don't support simultaneous audio output. Refer to your TV manual for details.
      • Check the BRAVIA Connectivity Guide for detailed instructions on how to connect an audio device to your TV.
      How to connect your TV and audio device
      To begin, select your TV model type below:
