Article ID : 00204653 / Last Modified : 10/02/2026Print
    The voice-enabled Amazon Alexa device suddenly no longer controls my TV
    IMPORTANT: This article only applies to specific products, countries and/or operating systems. For the applicable products, please check the 'Applicable Products and Categories' section of this article. For the applicable countries/regions where Sony's TV supports Amazon Alexa devices, please refer to this Supported Countries article.
    Before you begin
    First, check if your TV model uses the "TV Control with Smart Speakers" app or the "TV Control Setup with Amazon Alexa" app, then follow the corresponding steps below:
    For TV models with the "TV Control with Smart Speakers" app
    There are two possible reasons why voice control suddenly stopped working:
    • You've been signed out (maybe you haven't used this service for a while)
    • The link with the Amazon Alexa app (mobile app provided by Amazon) on your smartphone has been disconnected. If you received a notification in the Amazon Alexa app, following the notification may restore the link to the TV.
    Follow the steps below using your TV and smartphone.
    1. Sign in once again to the TV Control with Smart Speakers app on the TV.
      1. On the Apps tab on the TV’s Home Menu, select See all → TV Control with Smart Speakers.
      2. When the Account logged out screen appears, select OK.
        Note: If the Account logged out screen does not appear, you are already signed in. You can skip the sign-in steps below and go to the next item: 2. Link the Amazon Alexa app on your smartphone to the account registered on the TV.
      3. Follow the on-screen instructions displayed on your TV to input the activation code on your mobile device.
      4. When the activation code has been confirmed, tap Proceed to sign in on your mobile device.
      5. Sign in using the ID you have been using up to this point (either your Sony account ID or an Amazon, Apple, Facebook, or Google ID).
        Note: Sony has merged the IDs used with Sony product services into a single Sony account. If you select an Amazon, Apple, Facebook, or Google ID, the transfer to your Sony account will start. Follow the instructions on the screen to complete the transfer procedure.
      1. Open the Amazon Alexa app on your smartphone.
      2. When the Sony’s TV skill screen appears, tap Enable to use.
      3. Follow the on-screen instructions to link the account you are signed into on the TV to the Sony’s TV skill. The process is complete when the message Your BRAVIA account has been successfully linked is displayed. Tap Close.
      4. Additionally, make sure to select the correct Alexa device you want to use.
        Select the name of the TV displayed in Devices in the Amazon Alexa app on your smartphone, and select the Alexa device you want to use from Linked Alexa Devices.
        Note: Make sure the Alexa device name is dimmed and says Already paired with a device.
    Note: If you see different names for the same TV in the Amazon Alexa app, please refer to the Multiple TV names for the same TV in the Amazon Alexa app section in this article: FAQs for Using Amazon Alexa with BRAVIA TVs.
    For TV models with the "TV Control Setup with Amazon Alexa" app
    If the Privacy Policy for the TV Control Setup with Amazon Alexa app changes, you won't be able to use voice commands to control your TV with Alexa. To keep using Alexa for TV control, you'll need to agree to the updated Privacy Policy.
    You'll see a message about this when you try to control your TV with Alexa after the Privacy Policy update: "The Privacy Policy has changed. Please run TV Control Setup with Amazon Alexa to accept the changes".
    When this message is displayed, you can agree to the new Privacy Policy by following these steps:
    1. Select the TV Control Setup with Amazon Alexa app.
      For Android™ OS 8.0 or later
      1. Press the Home button on the remote control.
      2. Select Apps.
      3. Select TV Control Setup with Amazon Alexa.
      For Android OS 7.0
      2. Select TV Control Setup with Amazon Alexa in the Apps category.
    2. When the Privacy Policy screen is displayed, select Agree or Proceed. Scroll down and display the full text of the Privacy Policy to select Agree or Proceed.
    3. Confirm that you can use voice commands to control the TV with Amazon Alexa-enabled devices.
    Note: The Amazon Alexa App is a mobile application provided by Amazon.
    Attributions
    *Amazon, Alexa and all related logos are trademarks of Amazon.com, Inc. or its affiliates.
    *Google and Android are trademarks of Google LLC.
