Article ID : 00202482 / Last Modified : 10/02/2026Print
    Using the TV Menu / TV Menu Bar
    For models released in and after 2020, and those listed below:
    • A9G_AG9
    • XG85_X85G_U8G (55/65/75/85)
    • XG95_X95G
    • Z9G_ZG9
    • A9F_AF9
    • Z9F_ZF9 series with Android™ 9
    To access the TV Menu:
    • On your remote control, press the TV button while watching a TV broadcast to display the TV Menu.
    • You can check other TV programmes while watching the current TV programme. You can also change to a channel you often watch with one action.
    • If you want the TV Menu to disappear, press the TV or BACK button on your remote control.
    For other models
    To access the TV Menu Bar:
    • On your remote control, press the TV button while watching a TV broadcast to display the TV Menu Bar.
    • You can check other TV programmes while watching the current TV programme. You can also change to a channel you often watch or switch to a recently used app with one action.
    • If you want the TV Menu Bar to disappear, press the TV or BACK button on your remote control.
