IMPORTANT: For the BRAVIA 6 (A60) model, refer to the model-specific article How to adjust the date and time on the TV
The date and time are usually set automatically because the TV retrieves the date and time information from the broadcast signals or the network. If there are no broadcast signals or network connections available, you may need to set the date and time manually.
The steps to adjust the date and time differ depending on the TV. Choose your TV model type below.
Note: To check the type of your TV, refer to the article How to check if your BRAVIA TV is a Google TV™, Android TV™, or other TV.
