Article ID : 00124682 / Last Modified : 06/07/2026Print
    Unable to complete the software update when updating through the Internet
    There are various factors like connection and server errors that may prevent the television to complete the software update from being downloaded properly from the website.
    Follow these steps to troubleshoot this issue:
    1. Then unplug the power cable and plugin again. Or perform the RESET as below
      Refer to the following FAQ for instructions on how to RESET.
    2. Confirm the network status of your television by following the steps below:
      • For Android TV
        1. Press the HOME button on the remote.
          • For Android 8.0 only: Select App.
        2. Select HELP.
        3. Select Internet connectivity symptoms.
      • For 2014 models
        2. Go to Settings.
        3. Select Network.
        4. Select Network Setup.
        5. Select View Network settings and status.
        6. Select Check Connection.
        7. Select Yes.
      NOTE: Be sure that the local and internet access on the television are stable and the Physical Connection or Wireless Device on TV feature is set to OK or Found.
      If you have failed in this step, please remake a network.
      For details on network connection methods, also refer to the following FAQ.
    3. Check for a new version.
       For operation methods, refer to the following FAQ.
        How to perform a software update.
      NOTE: If a message such as New software version is not detected, appears, wait for a while, then try to update the software again.
    4. If you are still unable to update, try updating manually by downloading the new software on Sony’s support Web site to a USB storage device.
    *Android and Android TV are trademarks of Google LLC.
