Article ID : 00183074 / Last Modified : 16/01/2026Print
The time can't be set on the On timer setting.
    If the TV's language setting is one of the following, you may not be able to set the On timer setting using the remote control.
    • Bosnian
    • Catalan
    • Slovenian
    • Spanish
    • Turkish
    In this case, set the On timer setting after changing the language setting to English.
    1. Press the Home button on the remote control.
    2. Select Settings.
    3. Select Language in the System Preferences category.
    NOTE:
    • If you have a USB mouse, you can use it to set the On timer setting instead of performing the above procedure.
    • This issue will be fixed by software update.
      For how to update, refer to: How to perform a software update .
