Article ID : 00206052 / Last Modified : 19/01/2026Print
    Accessibility Shortcut
    IMPORTANT:
    Blind or partially sighted? Contact Sony using Be My Eyes
    If you aren't sure which Android™ OS is installed on your TV, check the Which version of the Android operating system is installed on my Android TV™ article.
    The Accessibility Shortcut function provides an easier and faster way to switch your favourite accessibility feature.
    Notes:
    • When the TalkBackScreen reader, and Text magnification functions are set to ON using the Accessibility shortcut, some edit options, including Move and Hide in Inputs, might not work.
    • When the TalkBackScreen reader, and Text magnification functions are set to ON using the Accessibility shortcut, some of the Quick Settings edit options might not work.
