You can turn off the LED light on the front of your TV by setting the Illumination LED to Off. Follow the steps according to your TV type.
Android TV models
- On the supplied remote, press the HOME button.
- Select
Settings.
- The next steps will depend on your TV menu options:
- Select Device Preferences → LED Indicator → Illumination LED → Off.
- Select LED Indicator → Illumination LED → Off.
- Select Illumination LED → Off.
Other LCD / LED TV models
- TVs released in 2015 or after
- Press the HOME button.
- Select Settings.
- Select System Settings or Preferences.
- Select Set-up.
- Select LED Indicator.
- Select Off.
- TVs released in 2014 or before
- Select Settings.
- Select System Settings.
- Select General Set-up or Preferences.
- Select Illumination LED or Front Panel Illumination.
- Select Off.
