Article ID : 00348663 / Last Modified : 06/11/2024Print
    How to reset or initialize the Wireless Headphones (INZONE H9 (WH-G900N) / INZONE H7 (WH-G700))
    Resetting the headphones
    If the headset cannot be turned on or cannot be operated even when it is turned on, reset the headset.
    Note: Resetting will not delete any data or pairing information.
    1. Connect the headset to an AC outlet.
      Use the supplied USB Type-C cable and a commercially available USB AC adaptor.
      The charging indicator (orange) lights up.
      INZONE H9:
      Illustration indicating the USB AC adaptor (A)
      INZONE H7:
      A: USB AC adaptor
    2. Press and hold the  (power) button and  (Bluetooth) button for about 8 seconds or more.
      INZONE H9:
      INZONE H7:
      The headset will be reset.
    Initializing / Reformatting the headphones to restore factory settings
    Notes:
    • The configurations of various settings are reset to the factory preset values.
    • Bluetooth pairing information is deleted.
    1. Turn off the headset.
      Remove the USB Type-C cable.
    2. Press and hold the  (power) button and  (Bluetooth) button for about 10 seconds or more.
      INZONE H9:
      When initializing is complete, the left and right ring indicators (white) flashes 4 times.
      INZONE H7:
      When initializing is complete, the  (power) indicator (white) flashes 4 times.
