Article ID : 00252981 / Last Modified : 27/08/2025Print
    Where to find the power button on your BRAVIA TV (2018-2025 models)
    Looking for the power button on your BRAVIA TV? Depending on your model, you can find it on the side, back, front, or bottom of the TV.
    Knowing where the power button is can be helpful if you need a quick fix for a lost remote. When searching, keep an eye out for the power button  icon. Sometimes it can be hard hard to spot.
    To make it easier, here's a list of power button locations for BRAVIA TVs from 2018 onwards.
    Note: This article is categorised by model year, as well as TV series and model name. If you don't know them by memory, you can search for them using the:
    • Serial or terminal sticker on the back of your TV
    • Settings menu on your TV
    • Original product packaging
    • TV user manual
    Examples of correct TV model names (with series name in bold):
    • K-65XR90
    • KD-43XG81xx
    • KDL-43RF45x
    • XR-55A95L
    For easier navigation, click or tap an anchor link below to jump directly to your TV model year:
    20252024 | 2023 | 2022 | 2021 | 2020 | 2019 | 2018
    2025 BRAVIA TVs
    2024 BRAVIA TVs
    2023 BRAVIA TVs
    2022 BRAVIA TVs
    2021 BRAVIA TVs
    2020 BRAVIA TVs
    2019 BRAVIA TVs
    2018 BRAVIA TVs
    Can't find your TV's power button, or your model isn't listed above? Check the sides, back, front, and bottom of your TV. You can also find more details in your TV user manual.
    For 2014-2017 BRAVIA TV models, click or tap here.
